new to the site & I need powerstroke help
Old 10-15-2006, 08:02 PM
bigbadwolfe's Avatar
bigbadwolfe
bigbadwolfe is offline
I just got a 1997 f250hd powerstroke 5speed i cant get it to start it had been sitting in a basement garage for 1 year un started i alll ready put 2 new batterys fuel filter oil & air the wait to start light works as well as the glow plugs and relay i checked all the fuses the truck has 140thousand on it and hasent ran in a year please anyone with any help would be great p.s. the truck smokes white when trying to start it thank you very much
Old 10-15-2006, 08:41 PM
barebackjake's Avatar
barebackjake
barebackjake is offline
if its smoking when your trying to start its a good thing atleast its getting fuel.
double check the glowplug relay. how warm is it where your at? if it has a block heater plug it in. the tail should be somewhere round the front of the driverside frame rail. the block heater is on the driverside tward the back of the motor on the end of the oil cooler, above the oil filter.
with the new fuel filter it may be a little grumpy since theres some air in the system now. just keep them batteries charged as you try
NO STARTING FLUID!!! unless ya wanna big BOOM
Old 10-15-2006, 08:52 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
white smoke usually means the glow plugs aren't working. double check the relay with a test light and verify the glow plug with an ohm meter. and easier yet plug the block heater in like barebackjake said
Old 10-16-2006, 08:58 AM
cookie88's Avatar
cookie88
cookie88 is offline
And....Welcome to FTE!!
Old 10-16-2006, 10:41 AM
Stroker 94 1/2's Avatar
Stroker 94 1/2
Stroker 94 1/2 is offline
Try jumping the two big posts on the gp relay like you would on a starter.
Jump the two for about 15-20 seconds, jump in and try starting it.
I've had mine sound like its working (gp relay) but no start. I would jump the two post for a little bit and it start right up.
Hope you get er going!
Old 10-16-2006, 11:30 AM
Cuda_jim's Avatar
Cuda_jim
Cuda_jim is offline
Add a bunch of fuel additive in the tanks Stanadyne, Diesel Kleen ect. Old fuel can go bad or form algae.
Good luck! There's more help here when you need it. Let us know when she gets going.
