Go Back   Ford Truck Enthusiasts Forums > General > Garage and Workshop
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Garage and Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Is F-150 Still King?
  #46 (permalink)
Old 11-14-2006, 10:39 PM
frederic's Avatar
frederic frederic is offline
frederic has a great reputation on FTE. frederic has a great reputation on FTE. frederic has a great reputation on FTE. frederic has a great reputation on FTE. frederic has a great reputation on FTE.
Updated the schematic.
Wired the under-car control panel:
http://frederic.midimonkey.com/booto...r/IM002113.JPG
http://frederic.midimonkey.com/booto...r/IM002114.JPG
You can see it working, slow, then fast:
http://frederic.midimonkey.com/booto...r/IM002112.AVI
And made the baby-sized throttle pedal assembly, minus the pedal. I'm going to use a piece of aluminum for the pedal, and drill lots of holes in it for the "import ricer look" just because
http://frederic.midimonkey.com/booto...r/IM002119.JPG
What's cool is the ignition switch underneath allows for motor only, motor and lights, and in the spring-loaded "start" positon, it also simulates pushing the throttle pedal down for testing purposes. Obviously not something useful for daily use, but if it's not working I can lift the back wheels off the ground with one hand, and turn the key to "start" with the other, and see if something happens. Much easier than trying to prop the back of the car off the ground on my foot, turn the key to "on", then push the pedal inside the car with my hand.
The terminal was there for "start" so I figured I might as well use it.
  #47 (permalink)
Old 11-15-2006, 10:30 PM
frederic's Avatar
More progress. A little each day.
Mounted the upper steering column bearing block, bearing, and shaft collar:
http://frederic.midimonkey.com/booto...r/IM002120.JPG
Used scrap from the motor plate to make a lower bearing block support, then attached the bearing block, bearing, and shaft collar:
http://frederic.midimonkey.com/booto...r/IM002121.JPG
Installed the steering shaft between the two bearings and collars. Wow, it lined up perfectly. Not bad for tape measure alignment
http://frederic.midimonkey.com/booto...r/IM002122.JPG
Then removed the lower steering shaft support collar out of the bearing, and welded on the pitman arm:
http://frederic.midimonkey.com/booto...r/IM002124.JPG
If I can find a piece of 3/8-24 threaded rod tomorrow, I'll make the pitman to spindle linkage. All that is left (other than finishing the fiberglass work) is:
1. Pitman to spindle linkage.
2. Prime/paint chassis.
3. Tie electrical to chassis.
4. Make chain guard.
5. Make/Buy/Acquire steering wheel and make collar to attach steering wheel to steering shaft.
Not bad!
  #48 (permalink)
Old 11-15-2006, 11:58 PM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold
A little friction paddle applied to the rear tires by the brake pedal with an adjustable link may provide that last little amount of braking action you need and could serve as a park brake.
__________________
"Beam me up Scotty. There's no intelligent life down here..."
  #49 (permalink)
Old 11-17-2006, 03:40 PM
frederic's Avatar
Pitman arm Installed:
http://frederic.midimonkey.com/booto...r/IM002125.JPG
Steering mechanism complete, and reasonably aligned: http://frederic.midimonkey.com/booto...r/IM002129.JPG
Started making the steering wheel: http://frederic.midimonkey.com/booto...r/IM002131.JPG
Rusty brake rotors are useful!
  #50 (permalink)
Old 11-18-2006, 01:33 PM
houlster houlster is offline
houlster is starting off with a positive reputation.
Cool project..
  #51 (permalink)
Old 11-18-2006, 05:16 PM
Torque1st's Avatar
Posting Legend
Does that steering column have a crumple zone?
jk
According to the schematic battery current for the motor goes thru the ign switch. Wouldn't it be better to just have the motor current run thru K1?
__________________
  #52 (permalink)
Old 11-23-2006, 07:51 AM
tjc transport's Avatar
tjc transport tjc transport is offline
is it friday yet??
tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation.
you are down to 1 month. how goes the fiberglass wars??
__________________
Tom
JOIN THE NEW JERSEY CHAPTER CLICK HERE
owner of way too many fords.
  #53 (permalink)
Old 11-23-2006, 07:55 AM
frederic's Avatar
It can have a crumplezone, I figured out how to do it, but honestly, I'm not going to. He'll have a 5-pt harness from a baby seat a neighbor tossed, so it's not overly necessary and more work than it's worth.
It *will* have a bolt-through roll bar however. Made the flanges already.
And the steel part of the steering column is complete:
http://frederic.midimonkey.com/booto...r/IM002147.JPG
The steering shaft is hollow tubing, so I can shove wires down the length of it from the not-made-yet hornpad and come out the bottom by the pitman arm, so I can wire up a switch or two on the steering wheel. Not because it's necessary, but because my son likes to beep horns Will lathe out an aluminum horn button probably this weekend out of some scrap and see how that works out. I've already made the harness for the steering column, and there's 8 wires that go up the column, so I can down the road drive more things than just a horn. Not that he needs cruise, tilt, radio controls being that he's not even two yet. I was just thinking down the road when he's 7 or 8 and ready for a 3 HP B&S engine
  #54 (permalink)
Old 11-23-2006, 07:57 AM
frederic's Avatar
Quote:
It's cold, so I think I've lost the fiberglass wars
I think I'm going to head over to home depot this weekend and check out the "dollar a board" wood bin and pick up some thin stuff, dovetail and glue it together, and paint it. Probably a simpler shape like a jeep.
I took a break from the fiberglassing because I didn't want to make the nose, and have it interfere with the steering mechanism which wasn't complete at the time.
I should have started this last June, not last September. *sigh*.
  #55 (permalink)
Old 11-23-2006, 09:59 AM
is it friday yet??
Quote:
Originally Posted by frederic
It's cold, so I think I've lost the fiberglass wars I should have started this last June, not last September. *sigh*.
true, but we were having more fun tearing washing machines apart in the driveway and dumping the 2 quarts of gearlube in them all over the place
__________________
Tom
  #56 (permalink)
Old 11-23-2006, 10:03 AM
frederic's Avatar
It's always fun tearing stuff apart!
And the oil came up easily enough, I just dumped some kitty litter and left it overnight, and the next morning shopvac'd it.
No biggie.
  #57 (permalink)
Old 11-23-2006, 09:38 PM
Torque1st's Avatar
Posting Legend
The schemo still shows all the motor current running thru the ignition switch. Have you fixed that yet?
__________________
  #58 (permalink)
Old 11-23-2006, 09:41 PM
frederic's Avatar
Naaah, haven't updated the schematic or the wiring yet. You are correct, the motor does go through the ignition switch as it did previously. I did manage to get as far as digging out another ford relay with the same mounting method as the one's that there, but haven't rewired the connector, or welded the mounting tab on yet. It's sitting on my lathe at the moment as a reminder
  #59 (permalink)
Old 12-25-2006, 12:12 PM
is it friday yet??
merry christmas fred. did ya ever get the car finished???
__________________
Tom
  #60 (permalink)
Old 12-25-2006, 12:56 PM
"Beemer Nut" "Beemer Nut" is offline
"Beemer Nut" has a good reputation on FTE. "Beemer Nut" has a good reputation on FTE. "Beemer Nut" has a good reputation on FTE.
I think Fred's in the slammer, he was doing doughnuts drunk in the
street last nignt, nothing on but a Santa hat. Na, just joking, hope he
got it done in time for the little one.
He better have a blue oval hood ornament on the front.
Hey Fred, Merry Christmas.
__________________
.....=o&o>.....
Tags
il11cs , optronics
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
