window motor repair
IIRC there are 4 rivits that holds it on.
Roll window down about 1-2 inches. Tape it in place.
Punch out the center pins in the rivets and drill with a 1/4 drill. Punch out the rivets if necessary.
I did my rear door about a year ago. Couldn't find new lift arms/gears. The motor was fine so i welded and filed new gears on it. You can replace just the motor if that's what you problem is. A front door motor works if you get no listing at your parts store.
