1978 - 1996 Big Bronco
Old 11-18-2014, 02:31 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
Print Wikipost
88 bronco taillight removal
Old 10-14-2006, 09:07 AM
broncobob50's Avatar
broncobob50
broncobob50 is offline
how do i get the tail light lens off of the rear, are there hidden screws in the tail gate area?
Old 10-14-2006, 11:33 AM
dwoodler's Avatar
dwoodler
dwoodler is offline
2 from the tailgate side and two from the outside.
Old 10-14-2006, 11:41 AM
broncobob50
thanx for the info, i was afraid of that! my tailgate will not open due to a bad motor on my window. guess i'll have to fix that first.
Old 10-14-2006, 11:48 AM
dwoodler's Avatar
dwoodler
dwoodler is offline
Pull the inner cover from the tailgate then disconnect the wire at the two wire connector near the motor. Using a spare battery and a pair of booster cables (and a little ingenuity) -> hot wire the motor to lower the glass. If it wants to go up when you hit it the first time, just reverse the leads and it will lower. If nothing happens, then its the motor that is shot. Otherwise, it's one of the switches, the tailgate position switch on the top driverside latch, or wiring. Good luck.
cj_1776
05-05-2017 10:45 AM
Iaff113
01-09-2017 09:53 AM
eddieniner
2015 + Expedition & Navigator
06-05-2016 12:39 AM
00F350XL
Ford Truck Parts for Sale
10-25-2015 11:55 AM
rmalottwtes30
13
04-08-2008 05:34 PM
Quick Reply: 88 bronco taillight removal
