Molasses and rust removal.
Old 06-20-2009, 04:19 AM
Oz52F1's Avatar
Oz52F1
Oz52F1 is offline
My Door handle mechanisms went from rusted solid to silky smooth in a molassis bath......that was about 10 years ago.....still silky!!!!!
Its great for getting in nooks & crannys!
Enjoy!!!!
(BTW....."Mark in Japan" on the HAMB)
Old 06-20-2009, 10:13 AM
Fat Flatty's Avatar
Fat Flatty
Fat Flatty is offline
So when you say heat (warm water) helps speed the process up, do you or can you use a burner and keep it on low or something to speed this process up. 10 days seems like an eternity. I have lots of little bits, like the door mechanism that need rust removal, but media blasting is out of the question as it makes them all sticky later on. The other chemicals seem too harsh. We have a chemical cleaner at the shop, bakes the stuff at 300 degrees, not sure what is in it, but its non-toxic, but it doesn't remove rust, just paint, grease, oil, etc....
Old 06-20-2009, 10:48 AM
havi's Avatar
havi
havi is offline
I'll have the Roast Duck
I borrow a bubbling cauldron from the 3 witches of the North, full of molasses, and keep throwing parts in it. I keep stirring with a big wooden canoe paddle, while laughing out loud in a shrill voice.
Actually, I have an old fuel oil tank that I'm considering making a molasses vat out of (top half swing back on a piano hinge like a cooking grille). I keep reading about the molasses trick, and it seems like a neat way to go. Not a priority at this time, though.
I can imagine all the deer hanging around it during the Winter, too.
Old 06-20-2009, 11:29 AM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
The Guy who started this thread - 286Merc - had a 55 gal drum mounted over a fire pit and kept a charcoal type fire going. He mainly used it for engine blocks.
With a good fire you can roast all the little beasties that the smell draws - all you will need is a few frosties to wash the hard parts down.
Old 06-20-2009, 11:30 AM
grover's Avatar
grover
grover is offline
Wink
With a field full of Angus cattle not far away, I'd need to make sure my fence [s in really good shape before I tried the Molasses Method.
That, or I could post a sign reading "ANY CATTLE FOUND LICKING MY TRUCK WILL BECOME DINNER!"
I may have to wander down to the local Southern States and get some molasses. This is too intriguing an idea to pass up. I have some old tools with a little surface rust on them that would be perfect for a test.
Old 07-08-2009, 02:58 AM
muscletruck7379's Avatar
muscletruck7379
muscletruck7379 is offline
just tried it, but had mixed results (didn't get all of the rust, but still worked). came back to ask questions, and while rereading noticed that I need sulphated molasses... not what i stole out of the kitchen cupboard...
Old 07-08-2009, 04:42 PM
TxF100's Avatar
TxF100
TxF100 is offline
Question: Will the molasses become "spent" and not longer work after a period of time or amount of usage and not longer be effective for rust removal?
Old 07-08-2009, 05:24 PM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
Yes and no
It will slow down the time it takes to do the job - just drop in some more molasses to keep it gowing - kind of like sourdough starter.
NOTE: Molasses as we normally think of it is a thick syrup made from cane sugar - sulfated molasses is a animal feed available as a thick liquid or ground/chopped cane or sugar beet.
Stewart_H
508
09-15-2023 04:57 PM
pweng1
22
12-14-2014 04:41 PM
old broke prospector
09-26-2013 03:33 PM
HILLBILLY BOB
10-07-2012 07:11 AM
fastphil
04-22-2010 09:28 PM
Quick Reply: Molasses and rust removal.
