Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered, Classic and Box Style Ford Trucks SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 10-14-2006, 08:39 AM
merc546 merc546 is offline
merc546 is starting off with a positive reputation.
Nice Truck, Why would you want to recontour the stock brake pedal to the left side of the steering column?
Chuck
  #17 (permalink)
Old 10-14-2006, 09:53 AM
AXracer's Avatar
AXracer AXracer is offline
AXracer has a good reputation on FTE. AXracer has a good reputation on FTE.
makes good economic sense to spend up front for a solid platform, too many projects end up half done when started the other way around. Since 57's were the first to come stock with a 9" the rear axle may be stock. Check out the articles and specs tab at the top of the page for articles on rear axle swaps, they will give the dimensions of the various 9" axles Ford produced to check your against.
You might check out MP brakes www.mpbrakes.com for info and parts for your disk brake swap. If you go FDs do yourself a favor and add power as well. If you are sticking with the beam axle in front the Toyota power steering conversion is also something I'd suggest giving strong consideration to.
__________________
Passionate about autocross racing!
2003 GSL, 2005 HSL National Champion
1956 F100 Panel support/tow vehicle
2007 Solstice GXP racer, the "KRAZED KANARY"
2002 Celica GT 2003 GSL National Champion retired to daily driving duties
  #18 (permalink)
Old 10-14-2006, 11:07 AM
Col Flashman's Avatar
Col Flashman Col Flashman is online now
Col Flashman has a good reputation on FTE. Col Flashman has a good reputation on FTE.
Quote:
Chuck
Probably for the same reason I've been contemplating replacing mine w/ one from the same year T-Bird that mounts on the left side of the S.C.
As the Brake Pedal is less than a 1/2" from the Throttle Pedal, your foot can slip off the B.P. fully ingaging the T.P. causing an accident or if you've not correctly adjusted your brakes, you will wind up appling the Throttle as well as the Brakes as that B.P. sinks ingaging the other @ the same time if your foot is slightly off to the side.
__________________
Cheers
Colonel Flashman
Vermilion '58 Mercury M-100 HP 312 I-6 w/ HP C-4
Blue '58 Mercury M-100 Panel 223 I-6 w/ M-O-M
Black 1893 Henry Ford Quadra-Cycle (replica)
My Replies Are Not Meant In An Offensive Way.... Ever, They Are Merely.... Straight Answers or Comments
  #19 (permalink)
Old 10-14-2006, 11:25 AM
BR549az's Avatar
BR549az BR549az is offline
BR549az is starting off with a positive reputation.
Quote:
Originally Posted by Walston
Welcome, really nice looking truck.
Does the truck have original engine and front end?
Manual trany?
Thanks. very nice '60, by the way-wow.
OK- here's the story on the truck so far I believe:
Has been a western truck, but not sure of the particulars of who, where, and the all the dates at this point
It has one coat of paint on it since new- the original color is Aqua
At some point, probably about 20 years or so ago, somebody swapped in a (gulp, forgive me Henry) small block chevy v8 with gm alternator and power steering pump, Turbo 400 transmission, and a power steering setup. The guy also lowered it a bit, set it up for towing, and added a pretty nice set of buckets from possibly a 4th gen Mustang, and a stereo.
The guy that I bought it from in Ca has had it since April. I believe that he tinkered with it and gave up on it. From being underneath it, i can see that it has a newer professionally done daul exhaust system, brand new starter/solenoid, fuel pump, and shocks all the way around. He also claims that he replaced the alternator, and the belts look new.
It stills runs a bit rough (I don't think he ever got the points set up right), pulls pretty good when you try to stop, and the power steering isn't working very well if at all, and using aftermarket shifter is like trying to stab rocks at the bottom a of a mud puddle.
I'm not planning on restoring it, but I'm gonna DRIVE IT!!
The straight axle in front stays, so does the 5 on 5 bolt pattern, it's just getting some power brakes.
  #20 (permalink)
Old 10-14-2006, 11:48 AM
BR549az's Avatar
Chuck
Yeah- like Flashman says-
it reminds me of trying to drive a model A.
.....it's pretty tight between the steering column and tranny tunnel in certain situations.
maybe once I get some decent brakes, and tame the motor, it'll be driveable w/one foot. It definitely took two feet to coax it on and off the trailer.
*** thanks for the tip on the thunderbird pedal.
  #21 (permalink)
Old 10-14-2006, 12:24 PM
BR549az's Avatar
Yessir-I looked and looked around here for one of these trucks-
A guy down the street has a '59 for sale. It's a long bed, work truck with all the original mechanics--hasn't run in 10+ years, and has at least 150,00 miles. He won't take any less than $1000 for it.
There are three other listed locally- they're nice, original trucks, but the prices on them are $4500-$6000. The days of picking these trucks up for $500 is pretty much gone- around here, at least.
Thanks for the info on the rear axle swap- the axle does look just a little too wide, like maybe 2" or so.
Again- Thanks for the input, everybody.
  #22 (permalink)
Old 10-14-2006, 07:52 PM
bememe bememe is offline
bememe is starting off with a positive reputation.
Welcome! Nice to see another 57-60 guy joining the site. Get your gallery goin when the truck gets here. BTW I am in Glendale AZ, how bout you?
  #23 (permalink)
Old 10-14-2006, 08:05 PM
Fuzzy's Avatar
Fuzzy Fuzzy is offline
Fuzzy is starting off with a positive reputation.
I have a 58 I thought was nice.That truck makes mine look cheap.Ive neglected mine for a while.Just started messing with it again.Was rebuilding wheel cylinders and found Im not getting fluid to my rear brakes.So brake job is my next job also.
  #24 (permalink)
Old 10-14-2006, 08:16 PM
Fuzzy's Avatar
That front bumper is off an older truck.
  #25 (permalink)
Old 10-14-2006, 11:45 PM
Voneville Voneville is offline
Voneville is starting off with a positive reputation.
I think it's cool you're keeping the solid axle. I don't think I'd ever convert mine, I'm not sold that it's all that much better Like Overhead Valves, IFS is just a fad, I'm sure. The only modern amenity I want to add is a stereo system and modern seatbelts.
  #26 (permalink)
Old 10-18-2006, 12:21 AM
BR549az's Avatar
Quote:
Thanks, man.
sorry to take so long in responding- been away.
...I'm in the other valley- in Mesa, north of downtown.
I'll definitely post pics as soon as I get the truck back home.
wagon wheels, whitewalls, and all
Looks like you're doing some really nice stuff with yours.
  #27 (permalink)
Old 10-18-2006, 12:34 AM
BR549az's Avatar
Quote:
No way!
Looks like a garage baby.
would love to see mine black like that also, but want to drive it in the summer here in AZ...
Yeah, the bumper isn't correct, is it? i would like to find a grille bar and front bumper from a '60.
  #28 (permalink)
Old 10-18-2006, 12:43 AM
A fair amount of '57-'60 trucks have been found w/ the bumpers from the '56 year model mounted on them from the factory.
__________________
Cheers
Colonel Flashman
  #29 (permalink)
Old 10-18-2006, 12:50 AM
BR549az's Avatar
Quote:
right on- If I wanted a camaro, I would have bought one
  #30 (permalink)
Old 10-18-2006, 12:55 AM
BR549az's Avatar
Quote:
Flashman- where can I find an original style replacement fuel cap?
Thanks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
