We are heading into a part of the year with several safety issues
Old 10-12-2006, 11:43 PM
Greywolf's Avatar
Greywolf
Greywolf is offline
We have recently had a COLD WAVE in Memphis Tennessee:
1) Have you checked your heater to see if there is a dust hazard that could lead to a fire (especially one running through your ducting)
2) Those who plan on kerosene space heaters - is your wick any good, do you have adequate ventilation to use it, do you have at least ten feet around it that is clear of all obstructions and flammable materials?
3) How is the insulation around your doors and windows? Is it up to snuff?
4) If you have a wood stove, is the flue clean, do you have enough wood, is it insulated well around it so that it doesn't burn a wall or start a fire outside of it? Have you cleared summertime junk away from storage next to it that might catch fire?
5) If you have small electric space heaters - have they been cleaned so that there is no dust in them? Dust can ignite...
6) Is your propane or kerosene tank filled?
7) If you have a fireplace, has IT been cleaned? Is the flue clear and unobstructed by bird nests and such... (STORKS will do that...)
8) Have you looked at your attic vents, and closed them if you can, so that heat does not just run right out of your upstairs?
9) Do you have a CO2 monitor, and if you do - does it work? Does it need a battery?
10) DOES YOUR HEATER EVEN WORK! Test it - before it gets cold and you find you do not HAVE ONE...
~Wolfie sends
Old 10-13-2006, 07:50 AM
jake00's Avatar
jake00
jake00 is offline
FTE is my crack
We've had to use ours for awhile now.... I want a wood burning insert
Old 10-13-2006, 10:52 AM
93F250's Avatar
93F250
93F250 is offline
I got the winterizing bug last week and checked all of that stuff that applies at my place. It's been 40 degrees or less in the morning for a few weeks now. Winter will be here before we know it.
Old 10-13-2006, 12:26 PM
dono's Avatar
dono
dono is offline
Gone but not forgotten.
The air/heat tech was here this week to check out the heating system. We had a blast of Canadian air (thanks a lot, Dennis) and the temp dropped to 63. The weather report indicates we will be using the air conditioning again next week with temps in the 80's. T-shirts and shorts are still my daily uniform.
Old 10-13-2006, 08:31 PM
lariat97's Avatar
lariat97
lariat97 is offline
I have my heating & ac checked every yr. Its worth every penny it cost. I change the batteries in my smoke detectors twice a yr also.
Old 10-13-2006, 10:47 PM
70blue's Avatar
70blue
70blue is offline
Good point Greywolf. I just spent 120 bucks on insulation this morning that I plan to install in the morning. I got one room in the house that is not underpinned so its a big heatloser. I got alot of work to do this weekend getting the house ready. Thanks for giving everyone the heads up and pointing out the safety issues.
Another thing to consider is making sure your outside animals have plenty of straw bedding to keep them warm and don't forget to check your coolant in your vehicles.
Old 10-14-2006, 01:09 AM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
You're very welcome.
I too still wear Shorts & a T-shirt
at 5:00 pm today I was laying on the ground cleaning the harmonic balancer on my truck to re-paint the white on the 6*BTDC line getting ready to re-time the engine.
Temperature at the time 8*C or 46*F
I now have to phone for an appointment for the furnace and duct cleaning .
Old 10-14-2006, 04:06 AM
lenny1carl's Avatar
lenny1carl
lenny1carl is offline
timely..and great advice. having worked in the field all my life, i've seen too many disasters from people ignoring this stuff. great post
websthes
02-02-2009 11:03 AM
ford2go
01-17-2009 11:39 PM
cjben
07-08-2007 02:10 PM
websthes
12-14-2004 05:07 PM
78bigunns
02-26-2003 02:09 PM
Quick Reply: We are heading into a part of the year with several safety issues
