I have a friend back home with a97 identical to mine, but it has the 5 speed in it, and it was a xlt. Its such a nice truck with having a standard in it too.
The trucks with the manuals have reduced towing and payload capacities, though.
-Kerry
Thats just a little CYA from Ford for people that dont know how to drive a manual that well. My truck is rated at 2500 lbs. max, but most of its life was spent hauling a 5000 lb boat around and no problems have surfaced because of it so far.
I concur. Most of my truck's life (88k miles of it) was spent being used as an F-250 - hauling around a 16' work trailer, with a full ladder rack going over the cab (so, 'loaded down' would be putting it lightly), driven up and down the hills of central Pennsylvania (no small task).
I did some research and did get hold of the previous owner. He had to replace the clutch at 50k miles (well, with that load on that terrain, it's kinda obvious that's going to happen), but the tranny shifts well today (108k miles) for a truck manual, knock on wood.
I heard the reason for the down grade was the clutch, not the tranny itself... but I'm not too keen on owning a fullsized truck with a Mazda tranny... now ZF, that's a whole different story. You'd figure they'd have gone with a HD clutch.
Mazda tranny? Does that mean my Ranger has the same manual tranny as an F-150?
Last I understood, no. This is what I understood: there are two versions of the M5OD - one for small trucks, and one for larger.
Also, somewhere along the way the larger (and very probably the smaller) had an update of some parts. Hence, the M5OD I had in the 1993 F-150 is not the exact same as the one I have in the '99.
Yeah, the two trannies have different designators (r1 and r2, iirc). It's just odd that Ford didn't start down rating the large truck M5OD until the '97-'03 body styles.
