Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > Nevada Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Nevada Chapter Join Chapter, Leader:67 Olfthfl
  #1 (permalink)
Old 10-11-2006, 10:32 PM
oldfomoco oldfomoco is offline
Garage is empty, add now
oldfomoco is starting off with a positive reputation.
Question proper carb for a 72 F-250 w/390, 4spd 2wd
I am considering buying a 72 Ford F-250 2WD w/390, 4spd. It seems to run okay, but runs REAL RICH. Lopey idle, will stall if u dont feather the accelerator pedal, real black smoke out of the dual exhausts. Has headers and a 600 cfm 4 barrel holley on it now, owner says it's been rebuilt, I don't think so. Any suggestions as to which 4 barrel carb would work the best for mileage and performance? Thanks.
  #2 (permalink)
Old 10-12-2006, 12:08 AM
olfordsnstone's Avatar
olfordsnstone olfordsnstone is online now
olfordsnstone has a great reputation on FTE.olfordsnstone has a great reputation on FTE.olfordsnstone has a great reputation on FTE.olfordsnstone has a great reputation on FTE.olfordsnstone has a great reputation on FTE.
Edlebrock seems to have a good economic and low maintenance carb. Check out Summit Auto Racing. If you're in Northern Nevada, I know there is a Summit Outlet in Sparks. The folks at Summit are pretty knowledgeable about which CFM, Jet Size, etc, and will set you up with the right stuff.
Welcome to FTE! And welcome to Nevada Chapter.
__________________
Tim
05 F350 4x4 CC SB Tow Com 6.0 Auto (camper puller)
74 F250 4x4 w/ C8-460 4sp (restore project and wood truck)
07 Everest 295TS Fifth Wheel (rolling beer drinkin' den)
56 Sweetheart (wife)
These are my ladies
  #3 (permalink)
Old 10-12-2006, 04:30 PM
Thanks, I appreciate the input. I don't know why I didn't think of Summit!! I've bought from them before for an 88 Stang GT I used to have. DUH!! Old age creeping up on me I guess!! Thanks again!!
  #4 (permalink)
Old 10-19-2006, 05:59 PM
WillyB's Avatar
WillyB WillyB is offline
WillyB has a great reputation on FTE.WillyB has a great reputation on FTE.WillyB has a great reputation on FTE.WillyB has a great reputation on FTE.
Holly makes a good carb - you just have to dial it in for your application. Their website has directions and examples. I would sure try this before I bought a new one!
__________________
Willy B
Nobody ever went broke underestimating the intelligence of the American people. - PT Barnum
  #5 (permalink)
Old 11-01-2006, 08:14 PM
alanco's Avatar
alanco alanco is offline
1953 Ford F-250
alanco is gaining momentum as a positive member of FTE.
Best Carb for a 390
Quote:
Usually when it won't hardly idle, there is a problems with high float level, or a needle and seat which is leaking, or a plastic float which is leaking. It is super easy to replace the needle and seat in a Holley, it is all external. If the float is bad, adjusting the float level with the sight screw removed will fail, as it would with a bad needle and seat. Replace the needle and seat and adjust for float level. If you can't, then the float is bad. Another thing to check is a ruptured power valve. A backfire can rupture the diaphragm and cause fuel to dump in but not at idle. Get a book on a Holley, so you understand what you are doing. What I call the sight screw is on the side of the float bowl for the correct float level, and it is intended to allow you to adjust float levels with the engine running.
To learn the carburetors stock size jetting, you need its List Number which is on the primary side facing forward. take the air cleaner off and you will find it. You can go to the Holley web site and get all the stock sizes for your carburetor. The Holley, IMO, is by far the best carburetor for both performance and mileage. Problems like yours are common, and can be easily fixed.
Willy B is absolutely correct. And the 600 CFM is perfect for the 390. Unless the 390 was a high rpm built up motor, it does not need more, and the smaller size is far better for low speeds, and you will have better flow through the smaller venturis.
I have used Carter AFBs before (which is what the Edelbrock is) and they are rather finicky and require tons of parts sets to get the jetting corect.(Edelbrock is very good about proper jetting on a special order) When you live at altitude, you are wanting to lean out the stock jetting and that is where the problem begins. They use "step rods" for power enrichment and final jet size. The step rods eventually wear the jet and cause enrichment. Any increase or decrease in jet size affects the power jetting, so increases or decreases must be done with both step rods and jets. You also have to remove the entire carburetor top to work on this. The Holley, in contrast, is far easier to work on, and unless the base and center part are warped, the thing will last forever.
Regards,
Alanco
__________________
Fallon, Nevada, Cowboy Country
Old retired guy wrenchin' on my own and am a professional computer fixer/network techie. Selling out all Ford Truck Parts.
2004 GMC Sierra 2500 4WD 6.6L Duramax Diesel
80 Olds w/ FI Chevy 350/2004R & 8.5 10bolt Rear 4.11
Trucks must work or they are not trucks.......
Tags
390, 72, adjust, barrel, carb, carberator, carburetor, dial, engine, f250, f250w390, ford, lean, size, stock, truck, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
