F350 DRW/SRW wheel difference - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-11-2006, 06:53 AM
alchymist's Avatar
alchymist alchymist is offline
"Mifflin Clay"
alchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to behold
Anyone know right offhand if the F350 DRW wheels differ from the SRWs?
If so, are the front axle or wheel offsets different on the two models?
Inquiring minds want to know.
Old 10-11-2006, 10:55 AM
rvpuller's Avatar
rvpuller rvpuller is offline
rvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud of
The front wheels are offset in the front just like the back.
Denny
Old 10-11-2006, 11:08 AM
alchymist's Avatar
"Mifflin Clay"
So what you're telling me is the wheels on a SRW and a DRW are different. And then the front axle is different? Or is the front wheel to wheel width on the DRW narrower than the SRW?
Old 10-11-2006, 11:57 AM
EnviroCon EnviroCon is offline
EnviroCon has a good reputation on FTE.EnviroCon has a good reputation on FTE.EnviroCon has a good reputation on FTE.
The wheels on a DRW are completely different than a SRW. The hub mounting surface on a DRW wheel sticks out beyond the wheel.
As far as the axles go, I believe the SRW and DRW axles are the same. However, a DRW has a spacer bolted to each side that makes it wider. So a DRW front axle w/spacer is considerably wider than a SRW. This enables us to run the same wheels both back and front.
Old 10-11-2006, 12:30 PM
alchymist's Avatar
"Mifflin Clay"
Finally, the truth dawns - the spacer is the answer I was seeking - thank you.
I was unaware there was a spacer on the DRW front axle. So, I could put the spacer and the dually wheel on the front of a SWR.
Like the pics, too........
Old 10-11-2006, 01:43 PM
I've never known anyone that did that, but in all honesty, I don't see why you couldn't. Last time I had the front wheel off it looked as though I could've just un-bolted that spacer and put on a normal SRW wheel. So I don't see why it wouldn't work in reverse.
Old 10-11-2006, 04:39 PM
ryaneverk2's Avatar
ryaneverk2 ryaneverk2 is offline
ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.
I've seen pictures of the reverse, on a Dodge, where a dually had SRW truck wheels on the front. Looked a little funky to me. I'm partial to the wheels sticking way out on the fronts.
Old 10-11-2006, 05:06 PM
alchymist's Avatar
"Mifflin Clay"
Quote:
Yep, was considering the DRW rims on my F250. I really like the way they look.
Old 10-11-2006, 08:15 PM
BareBones BareBones is offline
BareBones is gaining momentum as a positive member of FTE.
I think the primary reason the DRW's have the same wheels all around is so that you don't have to carry two different types of spares!
Old 10-11-2006, 08:27 PM
alchymist's Avatar
"Mifflin Clay"
Yeah, thats' right. I just like the look of the offset wheel on the front. So if I should change the front wheels by adding the spacer, I should still only need one spare -the original. Should I have a flat on the front, remove the spacer and use the original spare. No?
Old 10-11-2006, 09:24 PM
ryaneverk2's Avatar
Are you wanting to put the dually wheel on the fronts and not on the rears? I think it's gonna look weird. On a dually, they stick out in the front, but it sort of compliments how they stick out in the rear, also...
You'll have to post some pics if you do it.
350 SRW and DRW differences bobv60 1999 to 2016 Super Duty 11 06-06-2015 12:38 PM
Difference between '99 F350 SRW and DRW jls8177 1999 - 2003 7.3L Power Stroke Diesel 14 08-30-2009 10:08 PM
dana 60 front axle - SRW vs DRW jwrboss302 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 07-07-2007 07:10 AM
WMS width difference between drw and srw? bigsub 1999 to 2016 Super Duty 4 05-21-2006 03:28 PM
F350 DRW / F450 DRW weldman Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 12 09-16-2002 01:01 AM
Tags
2005, 2006, axle, diference, differance, diffrence, drw, f350, front, rim, srw, swr, wheel, wheels, width
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
