97 Expedition My Awd Lights Flash On And Off
My Lights Keep Flashing On And Off On The Dash This Happened To Me Before When It Would Rain But Now There Is No Rain And It Is Just Flashing For No Reason The Problem Before Was Water Getting In Through The Dash Wetting The Gem Module But Now I Have No Clue Wats Going On Can Someone Please Help Me I Think It Might Be A Bad Relay But I'm Not Shure
Speed Sensors
there are two speed sensors related to this issue. They are on the transfer case.
if either is not working, the system defaults to rear wheel drive and the lights flash on and off.
It cost me about $300 dollars to get them replaced at the dealer on a road trip a couple of years ago. But not a big deal unless you need the AWD. I am betting that you can still put it into full time 4x4 with the switch on the dash.
Check your vacuum lines too
I have had similar problem, but mostly the lamps on mine would not go out, or flash a couple times, or just take lots of time before they would go out. I found the vacuum lines that control the front axle were damaged by battery acid. I had to cut and re-route several feet of the vacuum lines and that took care of many of my 4X4 control issues.
Just a thought, good luck.
Steve
Steve
does it happen when it rains if it does trust me get ur windshield checked trust me my truck use to bug out terribly in the rain it was doing its own thing when it rains water gets into the gem module and makes the truck short out go to the best windshield specialist u know and let reseal ur windshield make shure they check for the rust around the frame and fill any small holes water gets through call me if u need more info 917 604 5913
lawwich
04-06-2015 01:36 PM
n3up
1997 - 2003 F150
01-10-2015 07:55 PM
benny33
1997-2006 Expedition & Navigator
04-30-2014 07:05 PM
