Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 10-10-2006, 04:16 PM
Winsted Organics Winsted Organics is offline
Garage is empty, add now
Winsted Organics is starting off with a positive reputation.
Biodiesel Cold Start Trouble
been running b99 for the summer no trouble. This am 32 degrees and no start. Pulled fuel filter added regular diesel purged air from the system and put 10 gal of regular diesel from the bobcat into the tank to make a 50 50 blend. I've cranked it enough times to get some white smoke out of the tail pipe but it wont stay running. Feathered the gas pump to keep it running for about 1 minute. I've had it plugged in for 6 hours now and the fuel feels warm in the filter. Have I drained the batteries to the point where the crank speed just isn't enough? or is there a chance I burned out the fuel pump with the more viscous fuel?
  #2 (permalink)
Old 10-10-2006, 06:00 PM
cookie88's Avatar
cookie88 cookie88 is offline
2001 Ford F-250
cookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant future
f250juggernaut
The pump is pretty robust, I wouldn't replace it just yet. Have you tried jumping it yet? The Super duty is very dependant on strong batteries both for starting and for the glowplugs.
__________________
Scott
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods
Hers: 06 Freestar SEL 4.2l
79 Bronco Ranger XLT.. used be the driver, now waiting to become the project.
96 Grand Marquis LS... 25 mpg commuter
  #3 (permalink)
Old 10-10-2006, 06:02 PM
Just got back from jumping it. Spun faster, but still nothing. Any chance the engine is full of cold fuel? I saw that on some other threads. If so any way to purge it. It was catching at times with a pronounced knock, but now it just cranks
  #4 (permalink)
Old 10-10-2006, 08:03 PM
adambomb's Avatar
adambomb adambomb is offline
2005 Ford F-350
adambomb has a good reputation on FTE.adambomb has a good reputation on FTE.
Have you got it started yet? I doesn't get that cold where i live so i havent run into any problems with running BIO. Just to let you know the cloud point for B100 is 32 deg F.
__________________
2011 Escape Limited v6 (Loaded) ESP 7yr/65k and Full Ford Maintenance Plan
2005 F350 6.0 (modded) ~450rwhp/900+ft/lb tq
1999 F350 7.3 (normal mods + 13" King Suspension on 40's)
1998 F150 (basic mods + 7" Suspension on 35's/Prerunner fiberglass and skidplace)
1994 Bronco (normal mods + 9" Coil Suspension on 35's)
  #5 (permalink)
Old 10-10-2006, 09:49 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Quote:
Not always, it depends on the oil it was made from. The animal fat bio I've been working with gells at 45 deg, the mostly canola oil I'm using gells at 26 deg. The soy oil I've processed gelled at about 32-33 deg.
FABMANDELUX.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #6 (permalink)
Old 10-10-2006, 09:53 PM
1935 Ford pickup
Quote:
The lines to your Injectors are full of gelled fuel, If you cannot put it in a heated garage you'll have to blow out the lines with compressed air.
FABMANDELUX.
__________________
  #7 (permalink)
Old 10-10-2006, 10:11 PM
purge fuel lines?
Got new batteries so the crank is real strong. The biodiesel is from Twin Cities Biodiesel. Have not had a problem in two years, but I tend to switch end of September to regular fuel in MN. How does one purge the fuel lines
  #8 (permalink)
Old 10-11-2006, 01:30 PM
Moral if this repair is keep it simple. Why did it stop? Too cold. Cranked the heater in the shop up all the way. The ford outside temp guage read 100! Sat in there for 5 hours. Went out and it started like nothing was wrong. Done with Biodiesel for the season in Minnesota. Thanks everyone
  #9 (permalink)
Old 10-11-2006, 08:43 PM
cookie88's Avatar
2001 Ford F-250
f250juggernaut
The one time my truck froze up I would have killed for a heated garage. Glad you got it up and running again.
__________________
Scott
Tags
b100, biodiesel, cold, f250, problems, start, starts, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
