Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Early Broncos (1966 - 1977) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-10-2006, 09:35 AM
JCastellaw JCastellaw is offline
JCastellaw is starting off with a positive reputation.
351w and pulleys
We have the 351w sitting in the bronco and now we are trying to figure out the pulleys. My engine builder is trying to use the water pump off the 351w. He is also trying to use the 351w balancer. He said the water pump off the 302 would not work but I believe that has something to do with the balancer and the crank pulley. If I buy a 69 351w pulley will that allow the 302 pump to work and use my pulleys with the two adapters?
  #2 (permalink)
Old 10-10-2006, 10:27 PM
Boba Fett Boba Fett is offline
Boba Fett is starting off with a positive reputation.
Are you using V-belts or serpentine? What year is the Windsor? Is it a three or four bolt balancer? Should be a four bolt. 351W and 221 289 302 all have the same timing cover and therefore water pumps can be interchanged.
Serpentine.... i cant help you with that because i've never done a conversion.
V-belts.... once you know if you have a three or fout bolt balancer... or a new one with both patterns..... you can go to NAPA and get a set of stock pulleys for that year bronco with the accessories you have, PS AC whatever... they can get them if they know what they are doing. Next you need a stock bronco water pump for 302. The pulleys should work. If they don't, the crank pulley will be too far inboard the align with the water pump and alternator pulleys. Ford Motorsport offers Crankshaft Pulley spacers to step out the pulley.
If you are trying to mix and match junkyard pulleys.... forget it.... unless you can find the part numbers on them and cross reference them... NAPA can do that.... to determine if they will work you might as well be picking fly **** out of pepper with boxing gloves!
  #3 (permalink)
Old 10-11-2006, 05:37 AM
dk5122 dk5122 is offline
dk5122 is starting off with a positive reputation.
Quote:
That my friend is a good one. Never heard that one before. I'll have to remember it.
__________________
Dan's toys
76 Bronco V-8 36's
02 F-250 XLT Ext. Cab 4x4 35's
06 Mustang GT Vert
07 Escape 4x4
  #4 (permalink)
Old 10-11-2006, 08:40 AM
I have a 1985 351w that came out of a bronco. It has a 4-bolt balancer. he left the water pump on the windsor that came on it. He said either the pulley or the balancer would rub the 302 pump. I am using v-belts. He wants me to buy some pulleys off ebay Item # 180029124023 that might work. Then I would have to move the neck on my radiator. Seems like there should be an easier way. What if I bought a 69 3-bolt balancer. Does that solve my problems???
  #5 (permalink)
Old 10-11-2006, 06:25 PM
68 351 bronc 68 351 bronc is offline
68 351 bronc is starting off with a positive reputation.
It will work a lot better to get a water pump that has the right hand inlet than screw with the radiator. Nothing wrong with getting a good Miloden or similar pump from Jegs or Summit. Then stock EB rad hoses will work and fit perfect and the 351 will run cooler at an idel. 302 pump will have the same lenght drive shaft as 351. Everything other than deck height on both motors should be similar.
__________________
2001 F250 V-10 auto XLT 4X4
68 Bronco GT40 351w, NV3550 5sp, sweet!!!
  #6 (permalink)
Old 10-11-2006, 10:38 PM
NO
I think what you need is a water pump and crank pulley from a 75 Bronco, which should be four bolt. You should be able to get them from a parts store like NAPA that can get pulleys.
  #7 (permalink)
Old 10-14-2006, 06:23 PM
RCrawler's Avatar
RCrawler RCrawler is offline
RCrawler is gaining momentum as a positive member of FTE. RCrawler is gaining momentum as a positive member of FTE.
66-77 never used a 4 bolt balancer. There are a few places offering replacement 4 bolt balancers with new pulleys or redrilled 3 bolt pulleys.
If you have all of the original 302 accessories, use them. This is the simplest and cheapest option. Everything will interchange with no problem, and you won't have to mess with changing radiator ports or finding pulleys.
You can use the early 302 balancer on the 351, along with the water pump and all of the brackets for the accessories. There are a couple of adaptors to buy match up the Windsor head bolt pattern for the 302 accessories, but that is it. As 68 351W said, the only difference is the deck height and width.
Jason
__________________
"Giggity" Missing your Prius? Check under my tires.
'08 Dodge 2500 MegaCab 4wd, 6.7 Cummins, 6 spd auto, DPF & EGR fell off
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
  #8 (permalink)
Old 10-16-2006, 11:13 AM
My engine builder is gonna try using the 302 water pump and the balancer withe the pulleys and the adapters, but he think the 351w timing cover will work. Is that true and what problems is he gonna run into?
  #9 (permalink)
Old 10-16-2006, 10:11 PM
RCrawler's Avatar
The only difference in timing covers that I'm aware of is for a reverse rotation water pump and the provision for a fuel pump. It is possible that your late model Windsor used a RR water pump, but the 302 front cover will bolt on if needed.
Jason
__________________
  #10 (permalink)
Old 10-18-2006, 10:03 PM
Your engine builder must be a chev man. The questions he has are basic small block Ford stuff that has been around for years. Ford went to serpantine belt, reverse rotation water pumps, electric fuel pump about 20 years ago.
__________________
  #11 (permalink)
Old 10-19-2006, 11:04 AM
Yep! he is a chevy man!!!!
  #12 (permalink)
Old 10-19-2006, 02:34 PM
Eww... Sure you can trust him. Scary...
__________________
Dan's toys
76 Bronco V-8 36's
06 Mustang GT Vert
07 Escape 4x4
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
