A new transmission adapter - Ford Truck Enthusiasts Forums
Old 10-07-2006, 11:18 PM
Homespun91's Avatar
Homespun91 Homespun91 is offline
Homespun91 is starting off with a positive reputation.
Thumbs up A new transmission adapter
The new Wilcap adapter for Y blocks is now available for buyin'. Runs about $495. It adapts....the 700R4 to a Y. That's a GM auto OD trans, Vern. It may have been done for a month or two, but it wasn't last time I looked. I imagine it will work with the 200R4, the TH350, or the TH400 as well if yer inclined. Anyway....
Available from Wilcap directly, or Riley Automotive http://www.riley-auto.com/HOME_Page.html He's in the process of adding the trans web page, but it's not up yet. He's on the HAMB, good guy.
That makes, by my count, seven options for auto transmissions for Y blocks.
Ford-O-Matic; FMX; FlatOMatic C4; Bendtsen (any Ford trans); Gary Croan AOD; Hollywood Automotive AOD; Wilcap. Not too shabby for a powerplant that ten years ago was considered to be the armpit of Ford engines.
Old 05-14-2007, 12:22 AM
redlightning redlightning is offline
redlightning is starting off with a positive reputation.
Great info here.I am looking at the web page.
http://www.riley-auto.com/ADAPTERS.html
There is one listed for a 292 to TH350 for 225$.And a 312 to TH350 for 495$.
Do you guys know what the difference is.I thought the 292 and 312 both bolted up the same.
I know this thread is a little old.I did a search.
Old 05-17-2007, 02:07 PM
kooper909's Avatar
kooper909 kooper909 is offline
kooper909 is starting off with a positive reputation.
If you want to run a T5, where's the best place for an adapter for that?
This idea is probably a while down the road for me ... but I'm thinking about it.
Old 05-17-2007, 03:44 PM
juterbock juterbock is offline
juterbock is starting off with a positive reputation.
kooper909:
Try http://www.ford-y-block.com/ for the T-5 to Y-block. Until about 2 years ago I had a 61-unibody with a 292 and a bunch of parts to build a stroker that I wanted to put a T-5 behind. Unfortunatley where I now live I have no place to store or work-on my old truck so I gave it to the dude who bought my house. I still have most of the parts for someday in the future sort of thing, I never bought the new parts just scrounged ebay and swap meets in Ohio and PA for really good deals .
Old 05-20-2007, 01:19 PM
59flatbedford 59flatbedford is offline
59flatbedford is starting off with a positive reputation.
im planning on a nv4500 5 speed manual behind my 292. not sure what ill have to do but ill i have to do is find the tranny for the right price
Old 05-21-2007, 06:44 AM
The only reason I did not have the T-5 and adapter was finding the T-5 in good condition at the right price. (I'm cheap)
Old 05-22-2007, 06:32 PM
grover's Avatar
grover grover is offline
grover is starting off with a positive reputation.
Lightbulb
Quote:
I thought the 1600 that was in the original Pinto was the armpit of Ford engines!
Old 07-04-2007, 10:21 PM
HT32BSX115's Avatar
HT32BSX115 HT32BSX115 is offline
HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.
Does anyone know if there's a parking brake assy available for a 700R4 that will bolt on the back like the one that is on the back of our T98s??
I would consider a 700R4 behind my 292 if I could put an Ebrake on the back
Thanks,
Rick
Old 07-05-2007, 10:41 AM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is gaining momentum as a positive member of FTE.
Rick, I doubt that the drive shaft e-brake is available.
Old 07-05-2007, 02:24 PM
HT32BSX115's Avatar
This is one of the reasons I have an E4OD sitting in my shop.
It came out of my neighbors 94 Super Duty. He swapped the auto out for a ZF but he had to keep the E-brake assy for the ZF.
I won't have any problem finding one for it. I'll just have to buy a rebuilt one though. About $700!!
I was just hoping that there was an option for using a 700R4 the same way. I wouldn't need a trans computer then.
I don't have any problem with using a computer... (I am an EE...) But I would really like to keep it simple whenever possible.
Quote:
Old 07-06-2007, 11:30 PM
wild.bunch's Avatar
wild.bunch wild.bunch is offline
wild.bunch is gaining momentum as a positive member of FTE.wild.bunch is gaining momentum as a positive member of FTE.
Actually, the 1600cc Pinto 4 was a very good engine; it was called the "Kent." It originally came out in the late 50s and was still in production in the 90s. The engine was used in the Ford Cortina and is the basis for the "Formula Ford" racing class, which is where a lot of budding formula class racers get their start.
A famous use of the Kent engine was in the Lotus Elan (for those of you old enough to know what I'm talking about, Mrs. Peel drove one) for which a special aluminum twin cam head was designed.
A big fat Pinto was underpowered by this motor, but that's no reason to think it was in the same class as a Vega engine.
Old 07-07-2007, 03:30 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Thanks,
Rick
Go here and send them an email
http://www.tciauto.com/Products/GM/gm_4L60E.asp
We have trucks at work with 350/4 speed auto combos. Not sure about the ebrake. These are "one ton" walk in van chassis. I'll ask the mechanic about it. With the interchangeability of the GM stuff, you might be able to find an ebrake from a later trans that fits the 700r.
Old 07-08-2007, 11:35 AM
grover's Avatar
Thumbs up
Don't misunderstand me: I know the Kent had a great reputation prior to being the Pinto's first engine, and I would never, ever, compare even a bad Ford engine with the Vega engine. (I have always thought it was pretty funny that Pontiac refused to use the Vega engine when the Pontiac was told they would get a Vega-based Astre and chose instead the old Chevy 153, which became the "Iron Duke.")
Now, if the Kent had appeared in the Pinto with the Cosworth DOHC head and a pair of side draft carbs, things would be different. Sadly, Ford emasculated a perfectly good engine to prepare it for the Pinto. The later 2.3, however, made up for it. My parents bought a 1980 Pinto and drove the wheels off it.
T5 Install (start to finish) sere0501 1948 - 1956 F1, F100 & Larger F-Series Trucks 63 05-06-2015 10:13 AM
Lincoln Y block transmission to Ford Y block? ireding Large Truck 3 04-12-2015 09:30 PM
Wilcap still in business? FiftyF6 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 04-21-2014 12:12 PM
Who's got modern auto trans. On Y block? salf100 1961 - 1966 F-100 & Larger F-Series Trucks 1 04-23-2013 04:41 PM
AOD behind Y-Block? Icicle Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 10 02-28-2005 06:34 PM
Tags
1955, 1956, 239, 272, 292, adapters, adaptor, automotive, block, chevy, f100, ford, hollywood, speed, transmission, wide
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
