Ford Duraspark - Ford Truck Enthusiasts Forums
North Carolina Chapter Join Chapter, Leader:ncheavymetal
Ford Duraspark
Old 10-07-2006, 09:43 PM
tanman722001 tanman722001 is offline
tanman722001 is new and has a neutral reputation at this point.
Ford Duraspark
Have any of you guys put this set up on a older truck?I have a diagram.Just not to sure about it.Im doing it to my 71.It is almost ready to get it running again.But I have to get this wired up first.Let me know if you can help me figure it out.Thanks Tony
Old 10-07-2006, 10:35 PM
a11budman's Avatar
a11budman a11budman is offline
a11budman is starting off with a positive reputation.
Hey Now,
Sign on to yahoo or AIM...I know a little bit about the Duraspark
EDIT....Going to hit the sack now...just holler anytime and I'll be glad to help ya out...
Old 10-07-2006, 11:57 PM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
It isn't all that hard to wire up. I'd have to go look again for absolute accurate info, but I can say that the two wire plug to the box is the 12 volt and 9 volt supply, then you have the wires to the distributor and coil. Cranking voltage to the box is 12 volt, and the run voltage is 9 volt.
Old 10-19-2006, 04:06 PM
PerfDistIgnition PerfDistIgnition is online now
FTE Sponsor
PerfDistIgnition is starting off with a positive reputation.
If you decide to get a new distributor, consider our D.U.I.-Davis Unified Ignition or our custom curved Duraspark distributor. Please see them at:
http://www.performancedistributors.com/forddui.htm
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old 10-19-2006, 05:23 PM
5_labsownus's Avatar
5_labsownus 5_labsownus is offline
5_labsownus has a good reputation on FTE.5_labsownus has a good reputation on FTE.5_labsownus has a good reputation on FTE.
The site below describes how to go HEI! I did this to my 300 I6 and it works very good and IMHO it is easer to wire than converting to DS II.
NOTE: you must bypass the resistor wire on the ignition wire. It has to have 12V not 9V.
www.gofastforless.com
Old 10-19-2006, 10:37 PM
SCWIDVICIOUS's Avatar
SCWIDVICIOUS SCWIDVICIOUS is offline
SCWIDVICIOUS is gaining momentum as a positive member of FTE.
im thinking about doing this to my 65
Old 10-22-2006, 01:49 PM
ncfirefighter46's Avatar
ncfirefighter46 ncfirefighter46 is offline
ncfirefighter46 is starting off with a positive reputation.
i know me and me dad use to but this set up on our older trucks and i think we had to hook up on to the switch side of the (sil) and on to the coil. but the coil hat to changed to a electronic one. and it worked fine, i just use the old points on the older models i know the points up buy now are the cheap ones but you can still get the old good sets for under 20.00 made by borg warner and accel still have the ones made with the fiber board not the plastic. so i use the old style and i get about 6 to 10,000 miles out of them before replacing
GTG in Wichita Saturday HappyJack Kansas Chapter 4 11-16-2012 10:21 PM
Tony Wildman Chip smash fascism 1994.5 - 1997 7.3L Power Stroke Diesel 15 04-27-2011 02:31 AM
Hey Tony UnderTakr Kansas Chapter 11 10-01-2005 03:34 PM
2003 Ford Expedition Air Conditioning Problem Tony1974 Expedition & Navigator 8 06-14-2005 10:48 AM
rejet a new carburetor?????? 70T351W Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 8 06-02-2005 07:39 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1982, 78, 87, bb, box, diagram, duraspark, f100, f150, ford, hook, ignition
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
