Shift kit on 4R70W? Worth anything? Newbie to shift kits here >.<
Old 10-07-2006, 04:04 PM
Kijutsu's Avatar
Kijutsu
Kijutsu is offline
I'm not a big transmission person. To be honest, they scare the hell outta me.
So.
Question is this, shifts feel muddy. Not shifting firmly at all. It shifts on time but it's like it's taking it's sweet leisurely time to shift. No squeals or anything. I also notice that it'll downshift as I'm coming to a stop. I understand that it naturally has to downshift. But should I be really feeling it downshift while slowing down? It's like someone suddenly jams the brakes a little harder and I notice the engine revs just a little bit. Nothing serious (less than 500 rpms). So I'm wondering if I'm looking at serious transmission problems, or if I should see about installing a shift kit/having a shift kit installed.
Old 10-07-2006, 05:16 PM
zman764's Avatar
zman764
zman764 is offline
I really don't know a whole lot about transmissions either. But I have the 4R70W in my 97 4x4, and that is the exact same way mine shifts. I do not think you are having any problems from what you described. For around 280-400 dollars you can buy a programmer and get about 20 more hp and 30 or so more ft/lbs of torque out of your truck and make the transmission shift firmer. This should be better for the transmission than a shift kit too.
Old 10-07-2006, 05:18 PM
Mr.Novice's Avatar
Mr.Novice
Mr.Novice is offline
Hi, Kijutsu.
1) How's your transmission fluid level?
2) a)When was the last time you changed your transmission fluid, and
b)Which fluid did you use?
3) How many miles on your truck? Edit: Nevermind, saw your sig.
Old 10-07-2006, 06:54 PM
Kijutsu's Avatar
Kijutsu
Kijutsu is offline
Originally Posted by Mr.Novice
Hi, Kijutsu.
1.) Fluid level is good.
2.) Trans fluid was changed by dealership when I bought it (I checked it before and after the purchase.) Not sure as to what type.
3.) Sig is wrong, there's almost 103K on it now.
Old 10-07-2006, 08:19 PM
ncranchero's Avatar
ncranchero
ncranchero is offline
Sounds ok to me. Shifts just like the 4R70W trans's in my '98 F150 and in my '98 Interceptor. I am considering a programmer also.
Old 10-07-2006, 09:43 PM
lariat97's Avatar
lariat97
lariat97 is offline
My truck shifted slow before I used a Schip on it. It shifts quick & firm now. I have the E4OD. My 04 E250 & my 00 Grand Marquis shift like your truck. I think its normal.
Old 10-08-2006, 11:38 AM
skilife17's Avatar
skilife17
skilife17 is offline
Not to hijack this thread but I have a 97 F150 4.6 and 4R70W tranny and when I hit 30 mph after driving the highway, I can feel the downshift out of OD and it has been doing it for a while. I changed the filter at about 170000 miles and have about 191000 on it now. My fluid level is correct and not dark or smell burnt.
Old 10-08-2006, 01:17 PM
Kijutsu's Avatar
Kijutsu
Kijutsu is offline
It will downshift out of OD at ~30mph. At 30 mph you're lucky to be in 3rd gear, let alone OD. Sounds entirely normal to me. Unless it's downshifting hard?
Old 10-08-2006, 02:01 PM
fruth04's Avatar
fruth04
fruth04 is offline
if u want firm shifts a programer is the only way to go. in a WOT run my 03 5.4 just about chirps the tires upon the shift to 2nd in the towing mode......
Old 10-08-2006, 05:29 PM
Kijutsu's Avatar
Kijutsu
Kijutsu is offline
Programmers don't wreck out the transmission? I've heard it does. Basically the shift bands go to crap, if I'm not mistaken.
Old 10-08-2006, 05:39 PM
lariat97's Avatar
lariat97
lariat97 is offline
I've has my truck chipped for 100k & the trans seems fine. It shifts & pulls good. I've read that a programmer will make the trans last longer.
Old 10-08-2006, 06:29 PM
zman764's Avatar
zman764
zman764 is offline
In theory a firmer shift form the programmer means, less friction, less friction means less heat and less wear... making the tranny last longer... intheory. Also in theory this will put a lil bit more wear on ujoints and ring & pinion gears, and axles shafts, and wheel lugs... in theory.
Old 10-08-2006, 09:44 PM
Kijutsu's Avatar
Kijutsu
Kijutsu is offline
I could see the less friction and less torque, but why would it be more wear on the u-joints, ring and pinon geras, axle shafts and wheel lugs? There's no more torque being transferred to them is there? I mean. The torque is pretty much set by the gearing in the transmission. And, for aonther question, where would I get such a programmer and how much would one be?
Old 10-08-2006, 10:02 PM
zman764's Avatar
zman764
zman764 is offline
I have never read any of the stuff I said anywhere. But if the transmission shifts quicker and firmer, then the torque is applied quicker and firmer, making the driveline snap more instead of smoothley having more torque applied.
You can look online, I know motorheaven supports FTE or vica versa but if you search for the names of the individual tuenrs on google you can find good deals. I have seen them from 280-500 bucks for our trucks.
There is also an entire forum in here dedicated to them.
Old 10-09-2006, 10:21 AM
skilife17's Avatar
skilife17
Thanks for the reply. My dad told me it was normal. It's not really hard at all on the downshift.
Quick Reply: Shift kit on 4R70W? Worth anything? Newbie to shift kits here >.<
