Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 10-11-2006, 04:52 PM
StevensPoint StevensPoint is offline
StevensPoint is starting off with a positive reputation.
Does the SD HPOP do much for you if you if you're only running stock injectors? I need to replace my HPOP and would consider a SD, but I'm not willing to drop $2000 for new injectors to see the benefit.
__________________
2006 King Ranch
36,000 miles
  #17 (permalink)
Old 10-12-2006, 12:27 AM
RubberDuck's Avatar
RubberDuck RubberDuck is offline
Death Row Inmate #1
RubberDuck has a great reputation on FTE. RubberDuck has a great reputation on FTE. RubberDuck has a great reputation on FTE. RubberDuck has a great reputation on FTE.
SP, if you are never gonna run bigger injectors then there is no point in going to the SD HPOP. However, they are about the same price, and if it were me needing to replace my pump, I would do the SD pump. Cuz with it you can be sure your stock injectors are getting all the oil they need at all RPM's. It would just be the correct thing to do in my opinion. It's just a better pump, and if it works on our trucks, why not. And you don't need to spend 2k to reap the benifits of the pump. If you can afford a couple of days down time on your truck, and have the ability to wrench fairly well, you can build a set of injectors like I did for just over $400. I bought my injector kit, with some extra parts and machined intesifier pistons from Jim at DIY-injectors for $448 shipped. The injector build was really easy, and had great instructions. I'm not trying to sell them or anything like that, I just wanted you to know it doesn't have to be that expesive. Hope that helps.
__________________
RubberDuck
1995 F350 Crew Cab 4x4 dually
DIY Stage 2's/T.E. SD HPOP/RSB Diesel 140v IDM/1st Valair 3800# OBS Double Disk clutch/DP Tuner 2 pos. w/ custom switch/Gear Vendors OD/Good bye No.3 I'll miss you.
RIP #17
  #18 (permalink)
Old 10-12-2006, 07:51 PM
$500 is a bit more reasonable. I've replaced to injector o-rings and didn't find that job too bad. Thanks for the help.
By the way - Excellent Write-up!
__________________
2006 King Ranch
36,000 miles
  #19 (permalink)
Old 10-12-2006, 08:54 PM
RubberDuck's Avatar
Death Row Inmate #1
SP, thank you, I'm glad you enjoyed it.
__________________
RubberDuck
RIP #17
  #20 (permalink)
Old 10-12-2006, 11:04 PM
Sounds like you had not problem reconnecting the HP oil lines to the pump? Were yours threaded or snap? Mine are threaded, but I thought the newer style was different.
__________________
2006 King Ranch
36,000 miles
  #21 (permalink)
Old 10-12-2006, 11:32 PM
RubberDuck's Avatar
Death Row Inmate #1
Yeah, it was easy. You just take the fittings off the new pump which would be the snap on type. And screw in the fittings off your stock pump. It's that easy.
__________________
RubberDuck
RIP #17
  #22 (permalink)
Old 10-14-2006, 12:28 AM
Is the IPR interchangable between the two pumps? I notice the part numbers are very slightly different.
__________________
2006 King Ranch
36,000 miles
  #23 (permalink)
Old 10-15-2006, 01:06 PM
RubberDuck's Avatar
Death Row Inmate #1
Yes they are, but from what I hear you want to keep them correct. There were only slight differences in the two, but I myself didn't want to reuse my stock IPR. I wanted every upgrade I could get. I have no idea if you can get the same benifit with your stock IPR or not, but I didn't want to take that chance. That's just my opinion.
__________________
RubberDuck
RIP #17
  #24 (permalink)
Old 02-18-2008, 01:17 PM
wbeding wbeding is offline
wbeding is starting off with a positive reputation.
Hey guys, I lost one of the springs during the HPOP seal change. Are they entirely necessary? Is it bad if I take both of them out? Where could I find a new one? I have heard of just taking them out and nothing bad happens. What do you guys think?
  #25 (permalink)
Old 02-18-2008, 05:13 PM
RubberDuck's Avatar
Death Row Inmate #1
If you are talking about the springs under the fitting for the lines, yes take them out, they are just a restriction. International had put them there for bleed down, but there are holes in the little plates. But make no mistake, these are NOT responsible for the bleed down. Take them out and forget them.
__________________
RubberDuck
RIP #17
  #26 (permalink)
Old 02-18-2008, 05:24 PM
tjbeggs's Avatar
tjbeggs tjbeggs is offline
Fisher of Men
tjbeggs has a great reputation on FTE. tjbeggs has a great reputation on FTE. tjbeggs has a great reputation on FTE. tjbeggs has a great reputation on FTE.
Cody I would like to add some Torue specs to your write-up! not sure why we didn't do this a long time ago but here goes.
Pump mounting bolts (2)-16-20 Ft lbs
Drive gear bolt- 95 ft lbs
HPOP oil line fittings- 19 ft lbs
IPR- 35 ft lbs
Now everyone needs to save this in their Favs so they can link it later!!
__________________
Tim
1997 F-350 CC 4x4 PSD Auto 260K
I will keep My Money, My Guns, My home and My Family. YOU KEEP YOUR CHANGE!!
  #27 (permalink)
Old 11-15-2009, 11:22 PM
wildstang wildstang is offline
wildstang is starting off with a positive reputation.
Excellent write up RubberDuck, used it friday to install my adrenaline, helped a lot. I'll try to send reps.
__________________
Jim-1996 F250 CC Shorty 4X4 E4OD 7.3L Diesel
Mods: 6637 air filter,203 F t-stat from Diesel Site-finally heat! HPX line, Tymar 3-4 dp to 4" exhaust, E4OD "The Cure" 30K mod for now, 140IDM mod, ISSPRO ev1 egt, trans temp, boost, adrenaline HPOP med-oil
Powerstroke - IF your not being blown, your just sucking.
  #28 (permalink)
Old 11-16-2009, 11:54 AM
Fullcrew7.3's Avatar
Fullcrew7.3 Fullcrew7.3 is offline
Rice Rocket Eater
Fullcrew7.3 is gaining momentum as a positive member of FTE.
I would have had a great deal of trouble getting this job done without Cody's write up. Thanks for the torq specs Tim. Mind you, it's a bit late for me know. I kinda like Cody's torq specs. They're my kinda specs. 'Tight, but not too tight, if ya know what I mean'.
__________________
Fullcrew7.3
Dave
1996 F350 CC 7.3L PSD DRW 3.55 gears ,cat delete, 4" exhaust, 10k mod, kwik filter, EBPV E-brake, FPR shim, 40-20-40 split bench, SC 1705, Pyro and boost guages, transfer case ('93 F250) Stage 1 DIY sticks, Valair SMF, 203* thermostat, 3" DP, SD intercooler, 37/12.50/16.5's
Tags
73 , 95 , 96 , diesel , diesle , f250 , f350 , hpop , install , powerstroke , pump , replacement , replacing , switch , write
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
