Antifreeze types - Ford Truck Enthusiasts Forums
Antifreeze types
Old 10-05-2006, 11:58 PM
hop hop is offline
hop is starting off with a positive reputation.
Antifreeze types
Everything I see in Wally world is extended life that states it can be mixed with any other antifreeze in any engine. What gives? I have the green stuff in mine and don't find it around here. Can I or should I use this new stuff?
2000 EX 5.0 110kmi
Old 10-06-2006, 05:29 PM
borland borland is offline
borland is starting off with a positive reputation.
I noticed that Prestone has a reformulated antifreeze that mixes with any type antifreeze. It's also been reformulated to be "phosphate free" which now meets the euro car standards. It's not the orange Dex Cool extended life, but is labeled "extended life".
Old 10-06-2006, 07:53 PM
marragtop's Avatar
marragtop marragtop is offline
marragtop is starting off with a positive reputation.
How long has it been since you flushed the system? If it's been awhile, flush and replace all the coolant with new coolant. I personally don't like the 'extended life' coolants because I believe in flushing the system regularly. Just my 2 cents..
Old 10-06-2006, 09:33 PM
hop hop is offline
Been 2 yrs since the last change. I prefer to go with the green but it dosen't seem to be available anymore, everything is extended life. All the brands state for all systems. I don't think it's the same as the orange Dexcool.
Old 10-06-2006, 10:57 PM
4.0 Beast's Avatar
4.0 Beast 4.0 Beast is offline
4.0 Beast is starting off with a positive reputation.
i would use the motorcraft coolant. there are too many different types out there and from what i've read, you're not even supposed to use the yellow or orange extended life type of coolant in the explorers.
Old 10-06-2006, 11:14 PM
vloney vloney is offline
vloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant future
The difference came when the manufacturers went to aluminum and cast iron components. Put two different metals together, add a mildly acidic fluid with flow, you have a battery. I will at times stick a voltmeter lead into the radiator and ground to check---I've had up to 3 volts. The Dexcool and Motorcraft gold are formulated to prevent this.
Old 10-09-2006, 11:03 AM
MazdaRangerGuyInSTL MazdaRangerGuyInSTL is offline
MazdaRangerGuyInSTL is starting off with a positive reputation.
The motorcraft GOLD is good good stuff.. I HIGHLY recommend it.
I like the prestone stuff too... I suspect it's close to the same thing as the motorcraft gold, but can't verify this. Also I like the gold color... if you don't get all the green stuff out, it turns green.. likewise with the orange dexcool, this way you avoid a brown, muddy color.
Just don't be surprised if it makes your coolant look weak.. it's just because of the color.
Good luck
Antifreeze Trow93 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 14 07-30-2016 10:48 PM
reusing antifreeze brokeasajoke Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 12-17-2014 08:09 PM
Gold Antifreeze where to buy? perryg114 Excursion - King of SUVs 5 05-23-2014 04:07 PM
antifreeze jaybird8269 1967 - 1972 F-100 & Larger F-Series Trucks 5 07-27-2013 05:28 PM
Antifreeze recommendation paul Modular V10 (6.8l) 9 10-21-2007 12:22 AM
Tags
04, 2003, 2006, 60, anti, antifreeze, coollant, diesel, explorer, f150, ford, freeze, kind, truck, type, types
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
