95 f150 Hard to Start - Ford Truck Enthusiasts Forums
Old 10-05-2006, 06:19 AM
mikemustang289 mikemustang289 is offline
mikemustang289 is starting off with a positive reputation.
Truck is a 4.9L 5 speed and every morning, when the truck is cold, it takes a while to start. I have to crank it for about 10 seconds before it will start. When the truck is warm it doesn't do this.
Seems like a fuel, fuel pressure, or ignition problem. But I have no idea what it is. I have nothing to pull codes with but Check engine light is on. It has been on since I bought the truck but this recently started to occur. Any ideas??
Old 10-05-2006, 09:07 AM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
plug, wires, fuel pressure, battery condition, cap and rotor all good places to start to look for problems.
Old 10-05-2006, 10:55 AM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Try turning the key on and off about three times without cranking and then try to start it and see if it starts right up.
Let us know what happens.
Old 10-05-2006, 03:37 PM
alz alz is offline
alz is starting off with a positive reputation.
A bad ECT will give you symptoms like this.
Old 10-05-2006, 04:03 PM
Plugs, wires, cap, rotor are all good. Battery is not very old. Fuel pressure? how can I check this?
I have changed the fuel filter, MAF sensor, and TPS already. SUBFORD I will try what you said and see if that works.
What is an ECT?
Old 10-05-2006, 05:51 PM
94broncoxl 94broncoxl is offline
94broncoxl is starting off with a positive reputation.
ECT= Engine Coolant Temperature sensor
Kind of does what an automatic choke did for carburetors
adjusts mixture based on temp.
Old 10-05-2006, 06:08 PM
96f350rcsrw460zf 96f350rcsrw460zf is offline
96f350rcsrw460zf is starting off with a positive reputation.
Sounds like plugs. How many miles on them? They don't last as long in some vehicles as people think. I found this out years ago with the same problem. For what they cost and effort involved it might not hurt to try.
Old 10-06-2006, 10:32 AM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
pull codes first. www.fordfuelinjection.com will show you how using a paperclip its easy. dont start throwing money at an unknown problem.
the ect wouldnt affect a cold motor.
Old 10-06-2006, 11:36 AM
^^The ECT does affect a cold engine. The Ecu use input from The ECT sensor to enrich the air/fuel mixture when cold and during the warm-up cycle.
Old 10-06-2006, 02:37 PM
hutch1973 hutch1973 is offline
hutch1973 is starting off with a positive reputation.
I have the exact same issue with my truck. We've had a few cooler mornings the last week or so and it's acting the same way. Usually it'll pop off in a second or two, but like he said, at least ten seconds. The minute it fires up it runs fine, no sputtering or hesitation. If you fix yours before I fix mine, pass on the solution..lol. I plan on checking codes in the a.m.
I first noticed it when the temp dropped below 45 at night, and last night it got down to 38, definately worse. Need to fix it before winter hits, it's a long walk to work.
Old 10-06-2006, 03:53 PM
FYI, I pulled codes from my truck, and couldn't get anything. I'm going to pull the plugs and check them out in the a.m., once the thing has cooled down. I'm curious though, what is the point of the turning the ignition on and off 3 times...what does that tell you if it does start?
Old 10-06-2006, 06:52 PM
subford's Avatar
Quote:
When you turn on the fuel pump(s) they will run for one second to bring the fuel system pressure up for starting. If the fuel system drains dry it might take turning the key on and off about three times to charge the system up. If it starts up you know then that you have a bad check valve(s).
Old 10-06-2006, 09:15 PM
87fomoco's Avatar
87fomoco 87fomoco is offline
87fomoco is starting off with a positive reputation.
check valve ?
Old 10-07-2006, 04:06 AM
Turning the key on and off 3 times before I cranked the truck over seemed to work. The truck started on the first try. Where do I go from here, what are these valves you speak of?
Old 10-07-2006, 08:07 AM
subford's Avatar
Quote:
Now from doing the on/off thing we know it is the fuel system.
Most common cause would be a check valve in one of the FDM's.
Fuel injectors would let the pressure down but I do not think they would drain the fuel system dry, the same goes for the FPR.
Do you have a problem with one fuel tank filling while you drive off the other?
If so the tank that is filling is the one with the bad check valve.
Here are diagrams of your fuel system, FDM and the FPR.
Fuel system for 90-96 truck:
http://i54.photobucket.com/albums/g9...FielSystem.jpg
FDM from 90-96:
http://i54.photobucket.com/albums/g9...yAssembly2.gif
FPR:
http://i54.photobucket.com/albums/g9...Fuel/fpr02.gif
Any Ideas on this starting problem? JPSLLC 6.0L Power Stroke Diesel 3 07-24-2015 09:10 AM
6.0 No Start jlh542 6.0L Power Stroke Diesel 32 04-15-2014 01:20 AM
99 f 250 wont start since replacing oring oilpan/dipstick jfid 1999 to 2016 Super Duty 1 12-05-2013 06:38 AM
95 f350 7.3 turbo won't crank Wingwalker 1994.5 - 1997 7.3L Power Stroke Diesel 21 12-31-2012 09:17 AM
Won't start on first try when engine is warm fjones Explorer, Sport Trac, Mountaineer & Aviator 4 06-21-2001 06:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
