Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 10-05-2006, 05:00 AM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
Does anyone use the Diesel secret stuff?
Just wondering if any one uses this product. If so do you still need to get a kit from them to build a processing station, or do you use the same as other Biodiesel kits? They are very secretive, and won't give much info on the process, and what is needed to get started. I would assume that no matter what method you use, if you use waste vegetable oil, you need to filter out the suspended crud first.
thanks
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #2 (permalink)
Old 10-05-2006, 05:35 AM
Rushmore X's Avatar
2003 Ford Excursion
never mind, brain is not working efficiently this hour of the morning. I forgot one of the very helpfull things on this site is the search engine. Did a search and found more than enought to convince me that there is a reason that they're so secretive, and i'll go the way that has been more proven. still would like to know what everyone does to get the crud out of their WVO before the process is started.
__________________
  #3 (permalink)
Old 10-05-2006, 07:06 PM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is offline
Garage is empty, add now
bigredtruckmi has a good reputation on FTE.bigredtruckmi has a good reputation on FTE.bigredtruckmi has a good reputation on FTE.
I would start a new thread and ask your question to get better coverage. About the crud.
__________________
red 04 F250 build date 04/04 6.0 PSD ,auto,cc, xlt ,sb, moon roof, 4X4, off road pkg, sports pkg., tow pkg,camper pkg,FX4, electric shift on fly
93 f350 7.3 , 5 speed manual, ext cab, long box 240K+ miles
1967 C700 farm truck
30 ft travel trailer
Vietnam Vet/ OS1 USN/USNR retired 26 years
B5 soydiesel user
Sirius radio
  #4 (permalink)
Old 10-05-2006, 08:05 PM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
patfogle DaPocky
If you really want to get the "crud" out of it, you need to do the following. Buy a commercial deep fryer with a built in filtering kit, then use the magnesol filter pads. These can be ordered through a few different companies.. I think GFS (Gordon Food Service) has them too. You heat the oil to 200f and then filter it for no less than 15 minutes. This will remove any impurities and any crud.
__________________
1996 F150 Regular cab, SWB, 4.9. 5speed.
- Life is like a roller coaster, Live for the ups.
- Negativity begets hate, hate begets ignorance, ignorance begets stupidity. Don't be stupid.
- If you have to ask "Will this hurt?" do not proceed!
  #5 (permalink)
Old 10-05-2006, 09:40 PM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Quote:
Why? If you look in my gallery, you'll see what I built for less than 20 bucks and works just great. I used that system of cleaning for over 5,000 gallons! There are people that use a 5 gallon bucket with screens on this forum..................
FABMANDELUX.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #6 (permalink)
Old 10-06-2006, 02:51 AM
Rushmore X's Avatar
2003 Ford Excursion
thanks, will look at figuring something out. pretty sure will get into this, my 7.3 seems to like the stuff, and the removal of lubricants from diesel fuel has me a little concerned. I've spent enough money on the beast, may as well keep it around as long as I possibly can. Also have a VW to feed too.
__________________
  #7 (permalink)
Old 10-06-2006, 07:47 AM
jeep1947 jeep1947 is offline
jeep1947 is starting off with a positive reputation.
Right now I am using this while I build my bio diesel processor. Use the cleanest oil u can get. I let mine set for at least a week then pump off the best. First filter is through cheese cloth then a 10 micron water filten,then 5 micron carbon filter. Then I use a goldenrod particulate filter then finally a goldenrod waterblock filter. So far I have not had any problems stock 97 f250 edge EZ module on the 20HP setting. Jeep 1947
  #8 (permalink)
Old 10-12-2006, 12:34 PM
AndysFords AndysFords is offline
AndysFords is starting off with a positive reputation.
While we're on the topic I've been researching this DIESEL SECRET and found out the following: If you mix this according to their specifications, it will not thin the vegetable oil down enough to make much difference, and their secret additive is Xythol Paint stripper with mothballs in it. They got shut down in Europe for selling this stuff. However, if you have an old IDI diesel, SVO runs pretty good in it, I know someone who has been running it in a chevy 6.2 and has 17,000 miles, with no modification, not even a heater system.
__________________
1988 F350 7.3 Crew Cab 4x4 Dually C6
1984 F250 2 wheel drive 6.9 Extended cab 4 spd manual.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
