Dies in Reverse - Ford Truck Enthusiasts Forums
Dies in Reverse
Old 10-04-2006, 06:36 PM
KLoom KLoom is offline
KLoom is starting off with a positive reputation.
Dies in Reverse
My 1993 F150 dies when I put it into reverse. I have replaced the altenator and the ATF is full. Any suggestions?
Old 10-04-2006, 08:49 PM
rescuedranger rescuedranger is offline
rescuedranger is starting off with a positive reputation.
a broken motor mount?
Old 10-04-2006, 09:25 PM
fordfaninIL. fordfaninIL. is offline
fordfaninIL. is starting off with a positive reputation.
Which trans. does it have, e4od or aod? If you are not sure, the aod will have a flat pan that is fairly square. The e4od is rectangular with a deep channel that runs front to back and toward the drivers side. Do you have any of the forward gears?
2000 F350 sputtering in reverse Happy Beggar 1999 to 2016 Super Duty 0 10-12-2014 03:39 AM
Stalling in reverse perryg114 Excursion - King of SUVs 15 06-04-2012 07:59 PM
2001 f250 WITH V10 WANTS TO DIE WHEN SHIFTED INTO REVERSE alandscaping 1999 to 2016 Super Duty 7 09-15-2011 08:30 PM
Dies in reverse Jax Rhapsody 1978 - 1996 Big Bronco 9 08-21-2011 03:39 AM
truck dies in reverse ryquincarkay 1999 - 2003 7.3L Power Stroke Diesel 9 12-21-2007 09:30 AM
Tags
dies, f150, reverse
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
