65 f100 front end swap - Ford Truck Enthusiasts Forums
Old 04-06-2000, 10:40 PM
nj nj is offline
nj is starting off with a positive reputation.
I am looking at swapping the front end on my 65' f100 which has a 300-i6 and 4 spd manual with the front end out of a 94 f150 w/ 351 f.i. and auto trans. Has anyone done this before? Will the suspension/steering components fit-up without cutting/welding? Any help would be greatly appreciated.
Old 04-07-2000, 12:17 AM
mk's Avatar
mk mk is offline
mk is starting off with a positive reputation.
The engine/ trans combination sounds great, but you might be better off finding a 73-79 parts truck to get the discs from as they are a direct bolt in. The newer parts might not be worth the trouble. The steering box is mounted ahead of the crossmember from 80-up so unless you want to get into some heavy welding and fabricating, it's probably a good idea to stay with older parts.
Old 04-07-2000, 06:28 AM
jowilker's Avatar
jowilker jowilker is online now
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
nj WILL NOT CHANGE. 65-79 year models are the same and will interchange. All like parts will change out, and bolt in, but not past that.
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old 04-12-2000, 10:03 AM
truckin61 truckin61 is offline
truckin61 is starting off with a positive reputation.
Closed knuckle front end differences Amphihauler 1961 - 1966 F-100 & Larger F-Series Trucks 1 09-21-2016 04:28 PM
Crown vic front end swap Carmax 1961 - 1966 F-100 & Larger F-Series Trucks 5 08-23-2016 02:49 PM
front end swap Catfishoimc 1973 - 1979 F-100 & Larger F-Series Trucks 7 05-14-2014 10:19 PM
64 f100 steering box John Aary 1961 - 1966 F-100 & Larger F-Series Trucks 12 02-21-2013 06:25 AM
Wanna Drop My 65 jamminjameslhc 1961 - 1966 F-100 & Larger F-Series Trucks 25 07-10-2011 12:18 AM
Tags
1966, 59, 65, 65f100front, changing, clip, conversion, differential, end, f100, ford, front, swap, swapping, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
