53-56 Ford Bed Wood Size
The 5 center boards on the 53-56 F100 bed are the same. Does anyone know how wide each piece of wood on a 53-56 f100 bed should be? I want to make my own, but I have 2 measurements for the width of the board before rabets/milling: 5 - 3/4" and 5 - 9/16" wide. Also, if you know how wide the face of the board should be after rabets, that will help verify my measurements. I'm referring to the width of the wood that you see after you install bed strips.
Check out this link, its from one of our own. Down towards the bottom is a bed wood diagram.
http://www.clubfte.com/users/earl/Re..._Material.html
Good luck
Bobby
Good luck
Bobby
I found that same diagram from one of the members, but I also saw dimensions in the Dennis Carpenter catalog that said something else (5 - 9/16). I'm not sure which one is right. It's not a big difference between 5-3/4 and 5-9/16, but I'm afraid when you consider there are 7 boards x 3/16" difference each, that it will really be off. If someone has a stock bed with wood in it and can measure it, that might clear up what is right.
One other thing, do yourself a favor and do not cut the countersinks for the main hold down bolt washers until you do a test fit. You'll get a nicer job if you do a test fit and mark center from the bottomside.
CharlieLed
08-21-2016 08:37 PM
abe
03-12-2016 05:19 PM
