r420a refrigerant - Ford Truck Enthusiasts Forums
r420a refrigerant
Old 10-03-2006, 09:07 PM
davidsca's Avatar
davidsca davidsca is offline
davidsca is starting off with a positive reputation.
r420a refrigerant
anybody use this in their vehicle? I only recently heard about it so I'm asking the guru's
Any info/advice will be appreciated
Dave S
Old 10-03-2006, 11:08 PM
Ultramagdan's Avatar
Ultramagdan Ultramagdan is offline
Ultramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud of
It's a blend and is not pure like R12 or R134. It's basically freeze 12 that has been tweaked so that 1% of the R134a is removed, 1% of the R142 is removed and an extra 2% oil added. You can use a blend but you can do better going with the more common R134.
Old 10-05-2006, 01:54 AM
MazdaRangerGuyInSTL MazdaRangerGuyInSTL is offline
MazdaRangerGuyInSTL is starting off with a positive reputation.
Just stick with R12 or R134a... Problem is most A/C shops these days test the freon before evacuating, as they don't want to contaminate their entire batch.
If you've got weird stuff in there.. they won't touch it.. so if you ever need professional A/C service in the future, forget it.
There are also some legality issues in some states and the EPA.
Old 10-06-2006, 01:54 PM
hhott71 hhott71 is offline
hhott71 is gaining momentum as a positive member of FTE.
I hear that 10 gallons of water and this little blue super energy pill (the oil companies are supressing it) will give you 100mpg.
wanna try it on your truck?
<end sarcasm>
Stick with what works.
Where is serial # on 1946 or 47 half ton pick up? Trulyvintage 1947 and Older Ford Trucks 3 05-20-2011 11:40 AM
I need HiSPL Testing..... 3 08-19-2009 06:52 PM
I Beam Swap russellkr 1973 - 1979 F-100 & Larger F-Series Trucks 3 11-02-2002 12:18 PM
300 I-6 rogwelch 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 02-13-2000 12:29 AM
Tranny I.D. 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 01-28-2000 07:08 PM
Tags
1998, 420, 54l, 64, bronco, diesel, f250, ford, freon, oil, r134a, r420a, refridgerant, refrigerant, required
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
