Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-03-2006, 11:52 AM
akula22 akula22 is offline
akula22 is starting off with a positive reputation.
Shell Rotella T15w-40 vs Shell 5w-40 syn oil
Hey guys I was planning on switching to the new Shell 15w-40 cj-4 oil when i came out, but I was thinking since it will start to get colder in western pa next mon should I switch to shell 5w-40 syn oil for the cold weather? Does anyone here run this oil all the time and what are your real world opinions on this particular brand since it is the only one available at my walmart right down the road from me. I looked for the mobil 1 delvac 5w-40 oil but cant find any in the area.
  #2 (permalink)
Old 10-03-2006, 06:14 PM
t_b t_b is offline
t_b is starting off with a positive reputation.
Beach will be by in a moment to talk to you about Rotella synthetic, which is a very good oil.
If you want Delvac 1 5W-40, go to your parts store and look for Mobil 1 Turbo Diesel Truck oil in quarts - it is, by Mobil's own admission, the exact same oil under a different marketing strategy.
  #3 (permalink)
Old 10-03-2006, 06:42 PM
slowmans slowmans is offline
slowmans is starting off with a positive reputation.
i live in ma and run the 5-40 year round, cant seem to find the mobil 1 ? i have always ran syn. oils in all my vehicles ....
  #4 (permalink)
Old 10-03-2006, 06:48 PM
Beachbumcook's Avatar
Beachbumcook Beachbumcook is offline
Got Diesel?
Beachbumcook has a great reputation on FTE. Beachbumcook has a great reputation on FTE. Beachbumcook has a great reputation on FTE. Beachbumcook has a great reputation on FTE. Beachbumcook has a great reputation on FTE.
I use Rotella-Syn 5W-40 year round with great results. Use any brand of diesel rated oil you choose and look for the API industry mark showing that it is CI4+ rated (Mobil, Chevron and Rotella are the main ones).
I plan on maybe trying the new Rotella CJ4, but it is only 15W-40 dino for now, so I am not sure if synthetic CI4+ is better or worse than CJ4 dino? I emailed Shell oil twice to ask and have not heard back!!!
Here is a new twist or question....
Is running the new CJ4 oil while still using the current 500ppm diesel harmful as this new oil is designed for the new 15ppm diesel fuel??? I know that CI4+ can not be used in 2008 trucks/motors and with the new diesel... but what about CJ4 in older trucks (while running the current higher sulfur 500ppm diesel)?
Interesting question... which I hope someone knows the answer too or will have some time to email Shell, Chevron or Mobil.
Thanks,
__________________
03 Excursion 6.0L PSD
Magnafine P/S Fluid Filter
Racor By-Pass Oil Filter System
Dieselsite Coolant Filter
Bilstein Shocks/Rancho Steering Stabilizer
Fumoto Oil Drain Valve
BriteBox Headlight Module
Marinco AC Block Heater Plug
24" Wiper Blades
Window Screen - Radiator Bug Shield
Pioneer Airware XM Radio
  #5 (permalink)
Old 10-03-2006, 06:49 PM
tvsjr tvsjr is offline
tvsjr is gaining momentum as a positive member of FTE.
I can't find TDT in any of my local parts stores either (Dallas, TX). Looks like the next oil change (about 5K away... I assume I get a free oil change with a set of head gaskets...) will either see me ordering another case of Delvac from AvLube (fairly pricey) or swapping to something else... Rotella syn being the likely candidate.
  #6 (permalink)
Old 10-03-2006, 09:56 PM
A. Michael Foxtrot's Avatar
A. Michael Foxtrot A. Michael Foxtrot is offline
A. Michael Foxtrot is starting off with a positive reputation.
Thanks,
Since ULSD is supposed to be required by Oct. 15, I don't see this being much of a concern
http://www.chevron.com/products/prod.../ulsd.shtml#A2
edit: according to Chevron's website. they're CJ4 licensed oil will be available on Oct 15.
http://www.delobike.com/Chev%20CJ4%20Q_A.pdf
Same holds true for Rotella
http://www.rotella.com/press/article_68.html
__________________
(Cheap, Fast, Reliable...Pick any two)
1998 F-150 S/C XLT 4X4 4.6
2005 F-350 C/C Lariat 4X4 6.0
Click me to see what I drive
  #7 (permalink)
Old 10-03-2006, 11:09 PM
Got Diesel?
Thanks... but the new diesel will start to be phased in on October 15th, but they have until 2010 to be 100% 15ppm certified.
Here is a link...
http://www.eia.doe.gov/oiaf/servicerpt/ulsd/
__________________
24" Wiper Blades
  #8 (permalink)
Old 10-04-2006, 01:20 AM
from the link you posted
Quote:
up to 20 percent of highway diesel fuel produced may continue to meet the current 500 ppm sulfur limit through May 2010; the remaining 80 percent of the highway diesel fuel produced must meet the new 15 ppm maximum
I'm wondering where that "up to 20%" will land. It seems as though the majority of the fuel supply will be 15ppm
__________________
  #9 (permalink)
Old 10-04-2006, 08:41 AM
Got Diesel?
That's what surprises me... but I think that the conversion will be much quicker as to make it easier for refiners and distributors. They do not want to handle two of everything?
This is probably for "off-road", military and other "non-highway uses" I would assume???
__________________
24" Wiper Blades
  #10 (permalink)
Old 10-04-2006, 09:25 AM
Lonewolftx's Avatar
Lonewolftx Lonewolftx is offline
Road Runnin' Copper W
Lonewolftx is gaining momentum as a positive member of FTE.
Arrow Warm Weather tpes . . .
Thankfully those of us in the South OR the Republic of Texas don't have a need for the colder (Syn) oils so Dino is fine at the 15w and the new oil will be worked into the change cycle as it is available.
My personnal observation is syn is no better than dino in a warmer climate. Bummer for you Northern folks . . .
__________________
BtLW . . .
We're not here for a LONG TIME, We're here for a GOOD TIME! HOOH!
'06 F250 PSD CC SB LKR Fx4 20" Whls Dk Copper
http://www.ford-trucks.com/user_gall...id=130356&.jpghttp://www.ford-trucks.com/user_gall...id=136189&.jpg
  #11 (permalink)
Old 10-04-2006, 09:38 AM
kw5413's Avatar
kw5413 kw5413 is offline
kw5413 has a spectacular reputation. kw5413 has a spectacular reputation. kw5413 has a spectacular reputation. kw5413 has a spectacular reputation. kw5413 has a spectacular reputation. kw5413 has a spectacular reputation. kw5413 has a spectacular reputation. kw5413 has a spectacular reputation. kw5413 has a spectacular reputation. kw5413 has a spectacular reputation. kw5413 has a spectacular reputation.
With that said....I use syn oil...because I can...but, the main reason is my many short trips / run duration as my office is only minutes away and the stores that allow me to keep up with my honey do's (or dues as the case may be ) are even closer...
The additional cost is minimal for my perceived gain. While some throw thousands of $$$ at their trucks for performance gains, looks, lifts, etc...I throw a few extra $$ into the oil....But, that's just me.
__________________
"There is a fine line between fishing... and just standing on the shore looking like an idiot"
  #12 (permalink)
Old 10-04-2006, 11:01 AM
TheFist TheFist is offline
TheFist is starting off with a positive reputation.
Thats my opinion as well. My first oil change with the truck I've got is going to be with synth. oil. Probably the Mobile, unless I find a real reason to go with something else, 'cause I can get it at Wal Mart down the street.
  #13 (permalink)
Old 10-04-2006, 11:35 AM
shdwlkr's Avatar
shdwlkr shdwlkr is offline
shdwlkr is starting off with a positive reputation.
Just because someone mentioned the 20% of diesel still meeting the 500ppm sulfur level. I wonder if this is so that old tanks and lines that the new fuel runs through can be sold? I am told that in your vehicle it can take a few thousand miles to clean the tank, lines and injectors of the old sulfur fuel. So doesn't it make sense it will take a few thousand gallons to clean the tanks and lines the fuel runs through? Also the refineries don't have to switch over to the new 15ppm sulfur level fuel they can just stop making over the road diesel and make home heating oil instead wonder what would happen if enough refineriers stop making fuel, what would the EPA say then. I don't think it will happen but interesting idea.
As to oil I run shell 15 40 in my truck and have used this oil in my diesels since I got my first one in 1980 has worked good for me so that is what I will run until Black stone tells me it is hurting my engine. Don't know what is going on as I just did the first oil change last week and waiting for the sample kit to send in and see where my new engine is at the beginning and then see what the first 5000 mile oil change looks like.
  #14 (permalink)
Old 10-04-2006, 12:17 PM
Lonewolftx's Avatar
Arrow Not sure I agree . . . (don't you lov it)
Yeah, it is extra $$$$. Shell syn is $19.95 a gal vs. Shell dino $18.95 for 2.5 gal (Tractor Supply). You could change the oil much sooner, spend the same funds, and there is little to no evidence that syn does more for you than dino.
Spend away as it is your hard earned money $$$$$$$$ . . .
__________________
BtLW . . .
  #15 (permalink)
Old 10-04-2006, 12:26 PM
kw5413's Avatar
Value is determined by the one spending their own hard earned money. Personally, I typically don't make it my business to determine how others should spend theirs....especially when / if they desire to spend mucho grande bucks on mods that may or may not be of practical benefit.
__________________
Tags
15w40 , 40 , 5w , 5w40 , 64 , ford , mart , oils , rotella , shell , truck , uoa , v8 , vs , wal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
