1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
4R70W to 4R100 swap?
Old 10-03-2006, 07:59 AM
eviljarv's Avatar
eviljarv
eviljarv is offline
hi guys, i have a 99 expedition with the 4.6 with 190k and its time for a new transmission, my plans are to supercharge the expy sometime next year, would the 4R70 hold up to the supercharger? or would the 4R100 be a better option? do you guys know what would it take to go from 4R70 to 4R100? thanks for the help
Old 10-05-2006, 06:23 PM
eviljarv's Avatar
eviljarv
eviljarv is offline
any help guys?
Old 10-05-2006, 06:35 PM
fordfaninIL.'s Avatar
fordfaninIL.
fordfaninIL. is offline
You will have to find out if Ford even put a 4r100 behind a 4.6l. If they didn't, you might be out of luck. I have not seen one. If the 4.6l has the same bolt pattern as the 5.0l, then you would be able. Personally, I would keep the 4r70 and stick some money in that. From what I've seen, the 4r100 has many more weak points and problems. There are all kinds of Mustangs running around with aode's and 4r70's and they work fine.
Old 10-05-2006, 07:44 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,578 Likes on 1,288 Posts
Work your trans over. You wouldn't just bolt in a junkyard trans after you put a huffer on your motor, would you? You'd go through it. So go through the existing trans.
Here's some folks who can tell you more:
http://www.transmissioncenter.net/AOD.htm
scroll down, 4R70 parts are there.
http://www.becontrols.com/products/aodecat.htm
http://www.tciauto.com/Products/Ford/ford_aod.asp
Old 10-05-2006, 07:50 PM
bigsbetter's Avatar
bigsbetter
bigsbetter is offline
It would be a big hassle to do the swap. The wiring harness is going to be different. I think I would put the puffer on the 4.6 and see what fails first in the 4r70 and go from there.
Old 10-05-2006, 10:15 PM
eviljarv's Avatar
eviljarv
eviljarv is offline
thanks everybody, yeah, i looked into it and i think it would be too much of a hassle and a built 4R70 should be strong enough to handle the power i heard
Old 10-06-2006, 06:23 PM
fordfaninIL.
If you are going to stay with the 4r70, do some checking around before you jump in. The more research and questions you ask now will pay big in the end. Use a reputable builder.
Old 10-06-2006, 06:42 PM
eviljarv's Avatar
eviljarv
eviljarv is offline
thanks, i will, 85e150six4mtod posted some links for 4R70 parts, anybody know a good transmission company? or a good rebuild kit that i can have my local guy install?
BTclassics
1983 - 2012 Ranger & B-Series
03-03-2017 07:19 PM
Drober6473
02-14-2010 12:56 AM
rsylvstr
02-08-2007 09:22 AM
rev2fast
11-27-2006 05:27 PM
inoverdrive
Modular V10 (6.8l)
22
08-26-2006 11:06 PM
Quick Reply: 4R70W to 4R100 swap?
