Windstar Power Window Problem - Ford Truck Enthusiasts Forums
Aerostar Ford Aerostar
Old 10-02-2006, 11:55 AM
Markepling Markepling is offline
Markepling is starting off with a positive reputation.
Question Windstar Power Window Problem
1999 Ford Windstar driver's side power window just quit working.
The passenger side power window works just fine.
Both fuse panels checked - no blown fuses.
How can I fix this without paying a dealership $200.00?
Thanks anyone.
Old 10-02-2006, 03:45 PM
96_4wdr's Avatar
96_4wdr 96_4wdr is offline
96_4wdr is gaining momentum as a positive member of FTE.
Windstars are a totally different beast from an Aerostar
Aerostar is truck based similar to Ranger with different wiring circuits
Windstar is car based similar to Taurus
Old 10-02-2006, 10:07 PM
rickm5 rickm5 is offline
rickm5 is starting off with a positive reputation.
mark, first thing to do is check the power window switch on the drivers door. do you have a haynes manual? the switch section can be removed after pryingoff the drivers doorhandle trim cover, ( it may need persuasion with a small flat screwdriver wedged under the edges) then prying up the switch plate ...the manual says to check for voltage to the switch, then with switch in an "on" position, check for voltage to the motor. if you have no voltage to the motor with the switch in an "on" position, the switch is bad, ( you may want to try to verify this by bypassing the switch with a small wire to the motor to see if it will work, haven't done it myself) you can order a switch from your local ford dealer, or search on line possibly at ford-parts.com if you have voltage to the motor the manual says to disengage window from regulater and raise it up and down by hand to check for binding. (also a good time to recheck the motor to see if it will work with no load on it. if window is not binding and motor not working it may be the motor(replace).
its worth buying a haynes or chiltons to guide you a little. hope that helps... rick
1999 ford windstar lx "son of bean"
77, 400 mi.
1998 Windstar Pass. Window Problem Whitey Ford 3.0L V6 1 09-04-2010 11:32 AM
front power windows not working rooboy Explorer, Sport Trac, Mountaineer & Aviator 3 06-29-2008 01:34 AM
Power window don't work. windstarharv Electrical Systems/Wiring 1 10-06-2007 11:45 AM
Aerostar vs. Windstar 007bronco Aerostar 21 09-24-2005 03:13 PM
Need Fuse # For 1999 Ford Windstar 86Taint Electrical Systems/Wiring 2 08-23-2003 01:28 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
