Are there any adjustments on a AODE? - Ford Truck Enthusiasts Forums
Old 09-29-2006, 05:19 PM
mrb455 mrb455 is offline
mrb455 is starting off with a positive reputation.
I did a brief search and didnt find anything on if there are adjustments on a AODE (like band and pressure ect.)
Old 09-29-2006, 06:32 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Quote:
The AODE was only used in cars but if this is for your 1994 F150 then it has a 4R70W and here are the adjustments for it.
The PCM Computer adjusts the oil pressure as you drive.
Band Adjustment.
<dt> If you changed the Low/Reverse band or the planet check the band adjustment.
Low/Reverse Band - 1/4'' (selective servos)
Here's how to check it
</dt><dt>1. Install servo assembly into case. </dt><dt>2. Use the back of a hammer handle to push down the servo cover until it stops. </dt><dt>3. Measure the distance between the bottom of the snap ring and the servo cover. This is your clearance. </dt><dt>4. Adjust by grinding or welding end of servo pin. OD Band
Non Adjustable - However, once the pump is tight and the OD servo is installed take a pair of channel locks and make sure you can turn the output shaft in both directions. If the output shaft only turns one way the band is too tight. Fix it by grinding the pin shorter.
If you changed the OD band or reverse input drum check the band adjustment.
</dt>
Checks and Adjustments
NOTE:
Transmission end play can be adjusted using one of the selective thrust washers available for service. After measuring the depth, install the required thrust washer.
http://i54.photobucket.com/albums/g9...n/4R70Wadj.gif
Old 09-29-2006, 07:38 PM
It has a button on the shift leaver for the overdrive and a OD on the selector.
Old 09-29-2006, 09:14 PM
subford's Avatar
Yes it does, why the comment?
Old 09-30-2006, 07:43 AM
lostin90s lostin90s is offline
lostin90s is starting off with a positive reputation.
My 93,94 f150 has E4od trans is same as 4r70w ? My trans guy call it E4od. just wondering I want to calling by right name.
____________________________________
94 F150 XLT 4x4 SC LB Maf 302 E4od
Old 09-30-2006, 08:40 AM
subford's Avatar
NO.
The E4OD is an Electricaly controled C6 where the 4R70W is an Electricaly controled AOD.
There are only three differences between the 4R70W and the AODE.
1. Different gear set. (A wide ratio gear set in the 4R70W, hence the W.)
2. 4R70W uses a larger outside diameter slip yoke on the driveshaft which requires different extension housing.
3. 4R70W uses a better output shaft material for the higher torque of 1st gear.
Old 09-30-2006, 09:48 AM
Because I had a trans shop say it was an AODE, I am not that familiar with ford transmissions. Also the trans is beginning to lag between 1st and 2nd and I was wondering if there was any adj like the older ones that could help this.
Old 09-30-2006, 10:07 AM
subford's Avatar
The code on the door under "TRANS" will tell the type of transmission you have, you could also have the E4OD transmission.
If it is a "U" then it is a 4R70W.
Codes:
G = C6
U = 4R70W
E = E4OD
Old 09-30-2006, 10:10 AM
The code is a U, so it must be a 4R70W.
Old 09-30-2006, 10:46 AM
subford's Avatar
I think I would not go back to that "trans shop" as if they put a AODE in your truck you would not have as much pulling power.
There is not any
adjustments you can make on from the outside of the 4R70W.
Old 09-30-2006, 04:47 PM
There is no adj on the outside and the pan has 14 bolts in it also the pan is square with 2 corners slightly cut off.
AOD computer bypass tjdad62 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 03-17-2015 03:54 PM
FLOOR SHIFTER FOR AOD TJ62 1967 - 1972 F-100 & Larger F-Series Trucks 5 11-30-2014 12:23 AM
For guys using an AOD reed1951 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 01-02-2014 06:50 PM
AOD TV Cable Adjustment cwlightning03 1978 - 1996 Big Bronco 4 03-11-2009 01:19 PM
Towing with AOD?? Redneckerson 1987 - 1996 F150 & Larger F-Series Trucks 2 07-28-2002 11:57 PM
Tags
1994, 4r70w, a4od, adjustment, adjustments, band, e40d, e4od, end, f150, output, play, reverse, shaft, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
