1995 Ford F-150 with 4.9L... towing capabilities?? - Ford Truck Enthusiasts Forums
Old 09-29-2006, 04:56 PM
FyreLance FyreLance is offline
FyreLance is starting off with a positive reputation.
I have a 1995 F-150 with the 5-speed and the 4.9L engine. It is high mileage but very well maintained. I was wondering what kind of towing capability it has. It is hard to find towing information for the 6-cyl. trucks as I'm sure it is done much less often.
I actually only want to occaisionally tow my Trans Am to the track so that when I break it racing I can get it home. Is this possible, with a flat-bed or a dolly, as long as it's only done a few times a year?
Due to the fact that my buddy and I towed my Firebird Formula with his Bronco II and a tow strap with no problem, and I've hauled some hefty loads in my truck myself, it seems like it would handle it fine... but I wanted to get some advice. I am new to towing!
Old 09-30-2006, 06:23 AM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.
Your truck should handle that with no problem. The 4.9 is a torquey motor. My friend once pulled his Trans Am on a dolley with a 2.8 S-10. It did pretty well, much better than I had expected.
Old 10-01-2006, 11:38 AM
kcw12 kcw12 is offline
kcw12 is starting off with a positive reputation.
If you cant tow it 365 days a year somethings wrong. Ive towed 6 tons up very steep hills w/ my f150 300 six 5 speed. I Dont recommend it. but i had to get the cars and trailer up the hill.
Old 10-02-2006, 07:33 AM
DT 466Man's Avatar
DT 466Man DT 466Man is offline
DT 466Man is gaining momentum as a positive member of FTE.
trans am is nothing, 6tons of gravel on a 1ton trailer and i had enough power to go faster than 70 on the interstate, although i didn't. now braking was another story, it had no trailer brakes.
pulling it is not a problem, stopping it is
Old 10-02-2006, 08:51 AM
Thank you guys for the tips! I just wanted to be sure.
Old 10-04-2006, 01:40 PM
Toyman's Avatar
Toyman Toyman is offline
Michigan Chapter Ldr
Toyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputation
According to the Ford tow guide your truck should tow 3200#.
Toyman
Old 10-04-2006, 02:25 PM
That's a little under, but for only occaisional use it should be fine, yes?
Old 10-04-2006, 02:38 PM
andym's Avatar
andym andym is online now
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
Ford under-rates the tow capacity of the 300. You will be fine towing that car behind your truck every day if you wanted.
Old 10-04-2006, 02:39 PM
Great to know!
Old 10-04-2006, 08:52 PM
chrono4's Avatar
chrono4 chrono4 is offline
chrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to all
My last scraping truck was a 89 f150 with a 300 and a 5 speed, and I've pulled over 5 ton behind it, its all about gearing. If your truck has highway gears, it'll do it, it will just be doggy starting off. Now stoping, if the trailer/dolley doesnt have trailer brakes (mine doesnt) then you really need to be watching and give yourself the extra room. If you do pull it, go in the country and try some panic stops, see how it reacts to it.
1995 F150 towing capability yoda 1987 - 1996 F150 & Larger F-Series Trucks 17 08-11-2015 02:00 PM
SCT X4 Tuner ?'s 99 f150 6.7L Power Stroke Diesel 3 04-08-2015 09:52 PM
1990 Ford F250 towing capacity JMyers0901 1987 - 1996 F150 & Larger F-Series Trucks 1 05-09-2014 10:01 AM
Ecoboost towing ~9000# enclosed fiveohpatrol 2009 - 2014 F150 27 11-14-2013 07:41 PM
F150 HD vs. F250 mbutts Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 17 11-09-2011 12:05 PM
Tags
150, 1993, 1995, 49, 49l, capacity, f150, f250, ford, rating, spd, speed, tow, towing, towingcapabilities
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
