Spark Plug Torque 5.4 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-28-2006, 06:06 PM
FORDDIEHARD FORDDIEHARD is offline
FORDDIEHARD is starting off with a positive reputation.
I am sure this has been beaten to death but I was looking and could not find the proper info about proper spark plug torque for the 5.4 motor. What would be the proper torque for the plugs and is there a certain procedure to do this? Also was wondering what type of plug every one has been useing? I currently have a 2000 f-250,crew cab, 5.4 Triton motor, with 85000 miles on it and thought that a new set of plugs before winter would be a great idea. Also does anyone use either anti seize or thread locker on the plugs since there is only 4 threads that hold them in, any ideas would be greatly appreciated.
Thanks
Tim
Old 09-28-2006, 06:54 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie PowerstrokeJunkie is offline
PowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to behold
my CD manual says 15 Nm, and 11 lb-ft. i wouldn't know from experience, as i am not a sparkplugger.
Old 09-28-2006, 08:01 PM
FortyFords's Avatar
FortyFords FortyFords is offline
FortyFords is gaining momentum as a positive member of FTE.
As stated by our non sparkplugger friend ! That is the correct torque spec.
We use never sieze on the plugs ,we also change all boots when in there they can prevent misfires .Also we use dielectric grease on the end of the boot going over the plug ,then a little dielectric grease around the lip of the boot that seals to the head .This helps repell moisture and any water splash from getting down in the plug hole.
We also stick with the stock plugs ,because these engines seem to not like aftermarket brands.
ZRich
Old 09-28-2006, 09:30 PM
tigerman tigerman is offline
tigerman is starting off with a positive reputation.
Forty, I date back to spark plug wires, with distributors etc. I thought these new coil on plug engines didn't have "boots". Dah..h...h.
Old 09-28-2006, 09:38 PM
FortyFords's Avatar
I guess you haven't pulled a cop or plug out of your 5.4 yet then.
Boots - I wear a size 10,but my dad wore a size 11 that kicked my butt alot ,made me learn alot quicker back in the day!
HA HA
Rich
Old 09-29-2006, 08:21 PM
Thanks, Forty. You're right about that. I'm afraid too. Think I'll see if the O.E. plugs will go that 100,000 that Ford promised. Those buggers look awfully hard to get at in the back. And with all that delicate torque and few threads, I'll just wait awhile. Edit:::::::And you're also right about those boots that Dad wore.
Old 09-30-2006, 08:00 AM
Smile
Thanks for the input on everything probably going to change them out in the next couple of days.
Thanks
Tim
Old 09-30-2006, 09:28 AM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Tim, for some tips on replacing the plugs take a look in the Frequently Asked Questions at the top of the 97-03 F-150 forum.
Different truck but pretty much the same procedure.
Old 10-01-2006, 08:51 AM
Talking
Thanks Dave for the info I printed it out today and hope to get at the plugs this week sometime will let you all know how it went, gotta get some "Motorcraft" plugs first!!!!!!!!!!
Tim
Old 10-09-2006, 12:03 AM
bigin1978 bigin1978 is offline
bigin1978 is starting off with a positive reputation.
when I was at the dealership for the last recall , i asked the mech doing it about the plugs backing out , he told me that the plug holes are tappered to allow a machine to load and torque the plugs at the factory and that when using a standerd socket that the socket may bind in the holes making it feel like the pkugs are torqued but in fact they aren't. he said they make aspecial plug socket for the 5.4 that is tappered to fit the hole to provide the proper torque.
Old 10-09-2006, 12:55 AM
T18skyguy's Avatar
T18skyguy T18skyguy is offline
T18skyguy is gaining momentum as a positive member of FTE.
I saw on another site that the spark plug companies themselves are recommending that a hole chaser be used to clean the threads of carbon before installing new plugs. They say that the newer oxygenated fuels make 5 times more carbon than the old fuels and this builds up on the threads. Then when you go to torque it you are only crunching it into the carbon so you dont have the real metal to metal torque you need and this also makes the plug overheat and next she blows.
Old 10-09-2006, 01:08 AM
forumsearcher's Avatar
forumsearcher forumsearcher is offline
forumsearcher is starting off with a positive reputation.
I would say that most people just do it by feel. I would say that finger tight plus a half turn would be good. Most spark plugs have crush washers that seat to the head, it is not really critical to have it torqued perfectly. Just dont strip the plug, make sure it threads in finger tight first. Also check the gaps yourself, and use Anti-seaze on the threads of the plug. This is a life saver for the next time you are changing the plugs.
Old 10-09-2006, 03:42 PM
stevenn1's Avatar
stevenn1 stevenn1 is offline
stevenn1 is starting off with a positive reputation.
Thumbs up Special Spark Plug Tool
I bought this special spark plug removal/install tool from Sears (www.sears.com) and it helped a lot ($37 + s/h + tax):
KD Tools 3 pc. 5/8 in. Extended Universal Spark Plug Socket Set + case
Sears item #00942274000
Mfr. model #KDS41740
3 piece 5/8 in. extended universal spark plug socket set. Unique design includes 5/8 in. spark plug socket, universal joint, and extension in one piece. Allows for ultimate access while staying securely attached to the drive tool. Includes 4, 6, and 11 in. lengths in a blow mold storage case.
Also, depending on the year of 5.4L you have. The newer ones have 3 valves per cylinder (24 valves total that create 300 hp) and require a different spark plug, which might require a different type/size of tool.
Also remember to not change spark plugs in a hot/warm engine. Several mechanics have told me to change spark plugs on an engine that sat overnight cooling down. The colder the better. Changing spark plugs in a hot or even warm engine will increase the chances of stripping out the threads - since the newer style heads are made of aluminum. Make sure to use your torque wrench (approx. 15 ft/lbs) when installing plugs.
Also, the newer style spark plug wires (if you can call it that) do have a boot with a spring inside and all connected to the coil pack. Usually these boots are very reusable and do not give any problems.
Old 10-09-2006, 06:06 PM
Thanks much to all that responded sure get a lot of great advice from all you ford nuts, nice to know if a person needs some advice they can get it without a bunch of crap. Just ordered the 3 piece swivel set from sears looks like a "must have tool" for my set!!!!
thanks
Tim
Old 10-09-2006, 06:12 PM
Big Orn's Avatar
Big Orn Big Orn is offline
Big Orn has a very good reputation on FTE.Big Orn has a very good reputation on FTE.Big Orn has a very good reputation on FTE.
Quote:
HA HA
Rich
I bet that's not all your pop used to dust that **** of yours, Rich...
Correct Spark Plug Torque And Gap? (1999 E-150 5.4 V8) dbbldz 1968-2013 Full Size Vans 6 04-16-2016 06:44 AM
spark plug torque sjwelds 2004 - 2008 F150 3 06-19-2009 11:12 PM
Spark plug blowout mystery ronnadavid 1999 to 2016 Super Duty 18 07-09-2008 09:38 PM
Correct spark plug gap 02 Supercrew w/5.4 liter AU chick 1997 - 2003 F150 1 05-30-2004 08:35 PM
5.4L Oil Drain Plug Torque Spec? whalerron Modular V8 (4.6L, 5.4L) 5 09-01-2003 11:07 PM
Tags
2005, 54, ford, plug, plugs, proer, spark, sparkplug, sparkplugs, specs, torgue, torque, tourqing, triton, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
