48 F-7 gas milage!!
I am wondering the same thing. Its got to be better than that though, I don't think its possible to pour that much gas through a holley 94 two barrel. Hey john please tell me thats loaded with like 20,000 lbs pullin a trailer!!!! seriously, how fast were you traveling and about what kind of RPMs were you pushing? By the way, an awsome, really good looking truck!!!
Hey Scott,
my 8-9mpg is on STOCK!! wait till next spring when I put my 2 holley's on
hopefully I can knock the mileage down to 6mpg (i gave up trying to get my mileage any better this summer---new power valve,new jets, new plugs , new plug wires, 26 degree dwell at 475rpm---still CRAPPPP)
Originally Posted by snipa
thats great mileage! my 239 8ba get 8mpg driving in the burbs on flat ground-pulling nothing
I'm hoping for more. The other thing that kills mileage is RPM. If you're turing 3000 RPM on the freeway you're gonna "suck the gas" as it were!!
Higher compression, higher coolant temps, correct jets, and high gears are the recipe for better mileage.
Regards,
Rick
Regards,
Rick
Originally Posted by ALBUQ F-1
That's just not right. Have you got good compression, 180 deg. thermostats, and the timing/vacuum advance working correctly? It should get 14 easily. Usual problems are the Holley/Ford 94, 160 deg thermostats, and Loadamatic distributors.
Ross,
I have not tried testing the timing/vacuum advance-whats the best way for that?
I also have not checked compression-i do suspect that it is not so good (when it first starts up it's a little smokey, black sooty water-like stuff on floor under both exhaust
the other areas you mentioned i have checked, and are good
thanks!
thanks!
According to my 54/55 shop manual those years OHV 239's had 7.2/7.5 to 1 compression ratios respectively.
It's about as good as it gets. Compression ratio is DIRECTLY related to efficiency....(MPG for those of you in Rio Linda!)
The newer 292's for example had about a 9.5 or so to 1 comp ratio. You can still run regular but that's about the upper limit for it and if you get the timing advanced a bit too much it'll "ping". Timing will also affect mpg. (Too retarded will lower efficiency)
If you have smoky-sooty exhaust, install smaller jets in your carb. or check the float level...it may be way too high. Also change your air cleaner(if it's plugged)
All this stuff is pretty standard stuff. comp ratio is fixed though. you cannot change it unless you rebuild the engine.
Go down to the local autoparts store and get yourself an advance type timing light. You can actually measure your timing at different RPMs. This way you can determine if your distributor is advancing at the correct rpms stc.
Regards,
Rick
Regards,
Rick
Ross,
thanks!
thanks!
