Help with Axle Identification or part#.
I need to change the left rear axle seal because it is leaking axle fluid and contaminated the left rear disc brakes. But how can I tell what size ring gear I have. My axle code is a 26 which tells me the ratio is 3.73 non ls. I also checked the rear axle tag and it says the following:
3 S-116 L
373 10 2 1D18
I have a 2001 F150 4x4 5.4 liter Supercab with the 7700 payload package. I think the size is 9.75 but then I read somewhere may be a 10.25, can't tell from the axle tag. Basically I need to know so I purchase the correct size seals before I take everything apart and realize I don't have the right size. I purchased Motorcraft part BRS118 from the Ford Dealership but they didn't seem very confident that it is the right one. I also did a part lookup by my VIN number on the Motorcraft website and it shows BRS118 as an inner wheel seal. I was unaware there is an inner seal, I thought there was only an outer seal. If anyone can help me identify the ring gear size or even the right part# I would be eternally greatful.
3 S-116 L
373 10 2 1D18
Whitey Ford
15
03-01-2012 03:24 PM
mchurches
08-13-2010 09:24 AM
captrivers
05-24-2010 09:40 AM
