95 F350 E4OD Won't go into overdrive, shifts hard - Ford Truck Enthusiasts Forums
Old 09-26-2006, 03:03 AM
cmpcpro cmpcpro is offline
cmpcpro is starting off with a positive reputation.
Hi guys,
This is my first post. I bought a 95 F350 Crewcab long bed (Sold my 04 Silverado Z71 this morning) tonight and about twenty minutes after I bought it on the way home I lost overdrive. I spoke with the person I bought it from, and he told me I could bring it back tomorrow if I wanted but the thing is cherry. 460, 135k Dana 60/Sterling, for $5k. Looks brand new. Anyway, now that I lost OD, second and third shift noticably harder, and if you do a light brakestand with it, it makes a loud noise from the tranny, like a tapping. Also, before all of this happened (when I test drove it today, and it was fine) it has a longer than normal delay shifting into reverse, and then goes in hard.
The fluid smells burnt. But did before this happened.
Does anyone have any ideas what it could be? I don't know what to do, I like the truck, but I don't have the money to spend on a rebuild right now, and as of today I'm completely out of debt.. Oh, and it also makes noise when I put it in gear. Coming from the tranny. Put it in nuetral and it goes away...
Thanks guys
Chris<!-- google_ad_section_end --><!-- / message -->
Old 09-26-2006, 10:09 PM
Fal Grunt Fal Grunt is offline
Fal Grunt is starting off with a positive reputation.
Search for my posts, I had similar problems just recently. Your truck is a Kentucky truck too! Siblings, anyway...
MLPS may be your problem, thats what was wrong with mine. It's a fairly cheap fix approx $40, compared to a tranny rebuild. Course this is assuming that you have a E40D.
Course in comparision my truck isn't cherry... it was a work truck most it's life. 270k miles and climbing, it's on it's 3rd 460 and at least 2nd E40D, and it's second Borg-Warner Transfer case(through no fault of the first).
These are sweet trucks! I hope you find a solution to your problem.
Old 09-26-2006, 10:20 PM
Alright so im doing just about anything to avoid the school work that needs done!
http://www.ford-trucks.com/forums/51...-problems.html
See if anything helps you there. -myers
Old 09-27-2006, 12:34 AM
06fx4's Avatar
06fx4 06fx4 is offline
06fx4 is starting off with a positive reputation.
good forum this is
yup... glad you got rid of yer truck though
Josh
Old 09-27-2006, 11:19 AM
me too. What does that mustang got in it mr?
Old 09-27-2006, 11:58 AM
385seriesHemi 385seriesHemi is offline
385seriesHemi is gaining momentum as a positive member of FTE.
The truck could have possibly a burned up rear band i am sure and some clutches possibly also. Also once the fluid turns dark from the burned up clutches & bands, that tells ya you need a routine overhual unless the transmission was beat to crap. If you know a buddy that's a technician just have him go through the transmission for ya. other words I wouldnt dive into it yourself.
Old 09-27-2006, 12:12 PM
And also the hard shifting isn't necessarily bad, but its just a default setting the transmission fluid pressure higher.(i don't exactly know why) but thats what they do when something else in the transmission is not doing its job.
Say a piston in the rear drum has a bad seal and fuild is getting past. That tells the electronics thats tells the valve body n boost valve to raise pressure to push the piston against the friction and steel plates to engage say 2nd or 3rd gear n such. but the tapping noise, i don't know what that would be though. I hope my knowledge helped you somewhat
E4OD issues, lost cable driven Speedo...? IDIDieselJohn Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 01-05-2016 10:02 PM
'01 Expedition, torque converter or other tranny problem? lincolnboy73 Expedition & Navigator 13 08-17-2012 05:41 PM
torque converter clutch question ssjerrys Clutch, Transmission, Differential, Axle & Transfer Case 1 10-20-2010 11:19 PM
E4OD overdrive light on Tom Callan 1987 - 1996 F150 & Larger F-Series Trucks 7 07-27-2010 08:11 AM
E4OD Shifted Hard scottw1 Clutch, Transmission, Differential, Axle & Transfer Case 2 01-16-2009 05:17 AM
Tags
1994, 95, e4od, f150, f350, ford, hard, harsh, overdrive, reverse, shift, stay, tranny, transmission, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
