how to tell a 351c from a 351M?????
Old 09-25-2006, 12:52 PM
Farmall05's Avatar
Farmall05
Farmall05 is offline
Im trying to figure out if it is a 351M of a 351C some one has installed in a 71 f100 how can I tell without taking the engine apart??
Old 09-25-2006, 02:34 PM
roger dowty's Avatar
roger dowty
roger dowty is offline
best way imo is top radiator hose into block vs intake on w. also fuel pump bolts vertical vs horizontal on w...
Old 09-25-2006, 02:40 PM
Silver Streak's Avatar
Silver Streak
Silver Streak is offline
The two have different bellhousing bolt patterns. The C has the small block pattern and the M has the 385 series pattern. I don't know how far apart the holes should be on each, but it is an easily measureable amount. IIRC, the M also has a significantly taller deck height which would make the intake manifolds different widths.
Old 09-25-2006, 02:41 PM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
He was asking about a 351C and M not a 351W.
To tell the difference:
Engine Identification (rev):
351C/M/400 335 series: 8 bolts in rectangular valve covers. Timing chain housing is part of block. Thermostat housing on block. Exhaust bolt holes diagonal.
351M/400 335 series: intake is 12.7" wide the 351C is narrow.
Looking at the block at the base of the distributor the 351C will be even with the bottom of the intake manifold. With a 351M/400 there will be a ~1" high lip up to the bottom of the intake manifold.
Old 09-25-2006, 07:00 PM
Farmall05's Avatar
Farmall05
thank you for the information
Old 09-30-2006, 07:41 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
They didn't make clevelands after 72 so look for
D1AE - or D2AE casting numbers
351M's would have D7AE casting numbers.
Old 10-01-2006, 05:59 AM
rancheroman79's Avatar
rancheroman79
rancheroman79 is offline
actually they stopped production of the C in 74
Old 10-03-2006, 07:58 PM
slash31938's Avatar
slash31938
slash31938 is offline
so does that mean my cleveland valve covers will fit on my 400?
Old 10-03-2006, 08:48 PM
Torque1st's Avatar
Torque1st
Posting Legend
351C 351M and 400 valve covers interchange but some valve train components require tall valve covers to clear them.
Old 10-03-2006, 08:52 PM
slash31938's Avatar
slash31938
like roller rockers, etc? is the PVC valve needed, or can i use one of those racing breather things on the valve covers.
Old 10-03-2006, 09:56 PM
Torque1st's Avatar
Torque1st
Posting Legend
Some roller rockers require tall valve covers.
A PCV valve is required on any vehicle where you want the engine to live a normal life. Otherwise deposits will form rapidly in the engine and excessive wear will occur.
Old 10-04-2006, 12:01 PM
Falcon67's Avatar
Falcon67
Falcon67 is offline
351C vs 351M - look for a cast "fin" next to the distributor, most of the 351M/400 engines have that. Look at where the heads meet the block deck - 351M/400 deck is about 1" above the timing cover, 351C sits right on it. Look at the motor mounts if you can - 351C uses a similar mount to a 289/302/351W, 351M/400 mounts bolt to the side of the block using three bolts. As mentioned, the 351M/400 has a big (same as 385 series) bellhousing pattern. 351C has bell same as 289/302/351W.
gettler
46
12-16-2019 02:51 PM
Tinterat
04-18-2014 02:17 PM
Bob Crain
46
11-14-2012 07:00 PM
warecreek
01-25-2006 10:08 AM
carp1
08-08-2001 10:58 PM
Quick Reply: how to tell a 351c from a 351M?????
