You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I am trying to find out more ways to increse the boost and over all speed on my 02 hd. Not sure if I have to get a new super charger or what any Ideas?
Simply swap in a Lightning pulley (or a Lightning "boost" pulley for even more), the appropriate belt and then get a tuner to write a tune for it. Its done all the time, very easy to do. The HD SC is the same as the Lightning other than tuning the pulley size.
At least a couple of the vendors on this site, Jusnes Modified and Troyer Performance, can help with this
Ken is correct. IT is very simple. Many manufactures make lower pulleys that replace the stock pulley on the engine crankshaft. You can increase in in increments, anywhere from 2 pounds to 8lbs. You can order a handheld tuner, or get a custom tune on a dyno.
Right, it is as simple as changing the pulley. Depending how much boost you add, you may also have to use larger injectors to match the extra air with more fuel.
In either case, I would STRONGLY recommend you get this modified setup tuned on a dyno. I for one would not attempt to send you a mail order tune, because just guessing at the fuel needed is bad practice. You should be able to find a local speed shop willing to do this for you
I personally havent heard of anyone needing to swap out injectors with just a pulley swap, that is has typically been once you start swapping out blowers.
+1
The stock injectors are good for 450 to 500hp at the wheels before you need to upgrade them.
Sal at PSP, Jim at JDM, and Running With the Devil all provide very good custom email tunes. But, I would personally only use them until you can get on a dyno, so you can get everything from the mods you bolt on, in a safe manner.
Email custom tunes are common practice for the L's and HD's. They are better than the canned tunes preloaded on the Predator and SCT handheld, but not as good as a dyno tune.
As for where to get a lower pulley? I personally like Lightning Force Performance. LFP has very competitive prices and the product is very well built. LFP has a quick change lower pulley set up that is very popular.
Stewart
__________________ The Brotherhood of FTE <-click the link 1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft 1999 PSD F250 SC 4x4: 38R, Stage 2's, T-500, JW trans, Live Tuned, lotsa Riffraff stuff 2000 PSD Excursion 4x4: 38R, JW trans, F5, MBRP, AFE, OBA and Pre-Pump, V & B codes Never Fry Bacon NAKED!
Don't forget, on the HD you need to change out the upper pulley. A 2lbs Lightning pulley will not add 2lbs on an HD due to the larger upper pulley the HD has. First thing, get a Lightning upper pulley (or even smaller). That puts you in the ball park for Lightning boost. Then, if you need more, swap out the lower.
Give Jay a call on the pullies... he's got some leads on some of our sponsor companies selling them well under cost (demand went through the floor when the Lightning was discontinued). 770-736-7122 ext 105.
For intakes, Air Force One makes a damn good Lightning intake that will work, but the reliability of the company is questionable. They've had a hard time meeting delivery dates in the past.
Ok I got a Whipple 8 Rib Supercharger Blower Pulley
- Pulley Size(s): 2.75 Blower Pulley do you think I am going to have to get a lower pulley as well?
WHy order a whipple 8 rib pulley? Your truck has an eaton supercharger, not a whipple. You dont need to swap out the upper pulley, if you order a 6lb lower pulley for the lightning, it will up the boost by 4lbs on your HD. Also, get a new set of plugs, the TR6's gapped between .35 and .38 will suit you fine.
