Pop or Clunk When Turn Wheel Left at Low Speeds
Hi fellers,
Does anybody have any insight to the following TSB:
https://www.ford-trucks.com/tsb/tsb....y-2001/t-15502
I'm having this problem, but not often enough to be able to recreate the problem. Does anybody have the full text to this TSB, or any insight on what could be causing this?
Thanks!
Thanks!
Originally Posted by Mr.Novice
Hi fellers,
Thanks!
Thanks!
I took the tire off yesterday and checked for any "play" when I move the wheel assembly left/right and up/down. Everything moved as a unit, so I feel pretty good about that. The tie rod ends and uppper & lower ball joints all look good to me.
