Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 09-24-2006, 10:21 PM
JSpeed71 JSpeed71 is offline
Garage is empty, add now
JSpeed71 is starting off with a positive reputation.
Exclamation Air Conditioning/Heating issue- 01 HD
Hello all- new to the board Just purchased a 01 HD that needs some TLC. One of the problems I'm working is the AC/Heating system. Only distributes air through the defrost vents, no matter the position. Also, no blower motor speed change with corrosponding switch positioned. Jumpered the blower relay, blower motor works in all positions. Fuses at both the interior and engine bay panels have been checked and replaced with fresh fuses. Swapped the blower relay with a known-good relay, no change. AC works just fine, about 48*.
Outside of a obvious break in the wire from F24 to the relay, or a bad ground, what other cause can it be?
Without swapping the blend door actuator and checking the ground, any other possible issues? And where is the actuator located? Bad vaccum signal to the panel?
  #2 (permalink)
Old 09-25-2006, 07:04 AM
projectSHO89 projectSHO89 is offline
projectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to all
Outlet control is via vacuum. Check the vacuum line that runs behind the battery then through the firewall.
Is the blower on HIGH all the time? If so, check the blower resistor pack.
Steve
__________________
2001 F250 SD V10 4x4
HVAC FAQs: http://www.ford-trucks.com/forums/75...xpedition.html
Owner's manuals: https://www.fleet.ford.com/maintenan...ls/default.asp
It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.” - Mark Twain
Tags
aircondioning, blend, door, speed
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
