292 Firing Order "HELP"
Drove my 64 in the garage to do simple tune up.Points cond.Rotor,and Cap,Lost some wires off cap in process,if anyone can e-mail me diagram of Wire locations on Dist.E-Mail randyzzzzz(No Email Addresses In Posts!),ive tried every combination,is#1 Pass.side front.My distributor is in the back of engine, I even put all the old parts back on ,she still won't fire,Im beginin to think I have a ghost,something else has to be Wrong.
Need Help Randy
Need Help Randy
Randy,
From what the manual tells me, the cylinders are numbered 1 (being the furthest away from the firewall) thru 4 (closest to the firewall) on the passenger side (right bank) and 5 (being the furthest away from the firewall) thru 8 (closest to the firewall) on the drivers side (left bank). The firing order then is 1-5-4-8-6-3-7-2. Hope this helps....
Gene
Gene
How about asking in the Y-block forum? Someone there could probably give you better help if you still need it.
-Andrew
f250_64(No Email Addresses In Posts!), same for yahoo messenger
Nothing, and I mean nothing, stirs the soul, saying I'm a bad **** like lettin'em rip with a window shaking, fuel gulpin, carbon monoxide belchin, attention gettin, V-oh my LORD!-8!
-Andrew
