Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
General Diesel Discussion SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 09-24-2006, 08:18 AM
50jd60 50jd60 is offline
50jd60 is starting off with a positive reputation.
Question 4.5 PSD, wastegate or EGR
About the new 4.5 PSD, have heard it has the wastegate instead of the EGR valve, is this true, if so why would Ford go back to the wastegate system.
  #2 (permalink)
Old 09-24-2006, 10:18 AM
CanadaGuy CanadaGuy is offline
CanadaGuy is gaining momentum as a positive member of FTE.
It uses both. A cooled EGR system similar to that of the 6.0, and a twin-turbo set up with a waste-gate that by-passes the primary turbo and directs exhaust into the secondary turbo when boost gets too high.
I'd imagine they've gone back to the waste-gate system because of all the problems with the VGT system... it works great in theory, but has been quite troublesome in reality. The turbo on the 4.5 is similar (if not the same) as the turbo that will be on the 6.4.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
