Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Iowa Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Iowa Chapter Join Chapter, Leader: fellro86
  #1 (permalink)
Old 09-23-2006, 07:29 PM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
1978 Ford F-150
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
This is what happens when a tread lets go, but not completely...(pics)
Click the image to open in full size. The tire tread let go at 60 mph about 10 miles after I got going for the day, so it wasn't even hardly warmed up yet. The tread satayed attached about 18" off the tire, ripping the rear fill neck off and smashing the tube such that I couldn't use it, luckily the front tank fill was still tere, just knocked loose as well, but not smashed. It ripped the metal off where the mud flap was attached. This is after I had straighted it out some, the sheet metal was folded up to the bed floor..
Used to be a running board there, the chunk that is torn there is where it used to be. The fuel door won't stay open, no spring, and the plastic around the cap is broken away from the bedside. The support to steady the bedside is all bent to heck and torn off too.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto
Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
  #2 (permalink)
Old 09-24-2006, 08:54 AM
390fe 390fe is offline
1970 Ford F-100
390fe is starting off with a positive reputation.
Jason Kendrick
Ouch! Looks like it tore the box up pretty good. It sounds like the major damage was to the tank filler assemblies and the lower box side support. Good job for keeping it under control and thankfull no one got hurt.
Looks like that box has seen a few Iowa winters, too...
__________________
Jason Kendrick
'93 F350 Crewcab 5.8L
'70 F100 Custom 390/C6 (temporarily retired)
'93 Mercury Topaz 2.3L
'99 Ford Windstar SEL (bad transmission - For sale)
  #3 (permalink)
Old 09-24-2006, 09:18 AM
fellro86's Avatar
1978 Ford F-150
yep, the outside has spent some time in the muck... The big rust spot is where they piled ont he bobo after someone must have hit the side... It spent a few years as a coop truck... The inside of the box is basically rust free though...Makes me think about putting a flatbed on, just don't like the way they look on straight wheel trucks. The tire never lost air, just made a heck of a racket while it tore the truck apart. The area behind the wheel was bent clear up to the bed floor... I did some straightening to be able to run it, and had to take the running board off, since it was swinging freely, held up yet by 1 bolt.
__________________
  #4 (permalink)
Old 09-26-2006, 03:21 AM
wyldstallyn73 wyldstallyn73 is offline
Garage is empty, add now
wyldstallyn73 is starting off with a positive reputation.
Had a couple of those happen too. Most memorable one was a nasty old 77 E250. Earlier in the day I had just bought a new can of WD40 and set it against the passenger side rear wheelwell, on the way home that night the tire chucked the tread in a violent manner. After the dust settled inside, I noticed the WD40 was now siting on the dash
__________________
"It's not that I'm lazy,,,, It's that I just dont care."
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
