replacing ignition lock cylinder
09-23-2006, 08:12 AM
on
Can anyone tell me how to change the ignition lock cylinder on my 1994.5 f250 turbodiesel ?
Thanks
09-23-2006, 10:24 AM
it easy and here is how. first the lock cylinder needs to be turned to the run position. then on the underside of the steering column there will be a small hole (if it not there you need to remove the plastic underside of the column. then once you have found the small hole you need to push a small punch or other metal object in the hole and push the button up while pulling on the lock cylinder. then just push the new one in making sure it in the run position.
09-25-2006, 10:42 AM
on
Thanks, tj. It worked like a charm. Really appreciate the help.
Tom
09-25-2006, 11:35 AM
no problem tom!
here to help!
10-08-2006, 03:16 PM
on
Ignition switch 1999 F150
What is the removal procedure for an igntion switch on a 1999 Ford F150?
10-08-2006, 04:16 PM
Quote:
Same as the post above from tjbeggs. It,s very easy to do.
10-08-2006, 04:29 PM
on
cda_jim thanks for your reply,
the 1999 has a PATS key, a chip in the key. any idea what it involves to get the new key programmed?
Garry B.
02-08-2009, 12:27 PM
on
1973 f-100
Is this the same for a 73?
Thanks,
Dawn
02-08-2009, 02:57 PM
drbushong
Thanks,
Dawn
I have never done one on an older truck like. Sorry I am not sure but I would guess they are the same.
Edit: On a 73 it might even be on the dash rather than the steering column. Not sure.
02-08-2009, 04:43 PM
on
Thanks Tim, I will check it out. I know it is on the column so I will check to see if it is the same.
Dawn
earlybirds
12-03-2016 10:10 PM
Donald Becknel
01-12-2010 08:05 AM
B-DOGG
1983 - 2012 Ranger & B-Series
03-19-2006 02:10 PM
