Fuel Puddle in the Valley
Today i was lookin around and found a small puddle of fuel in the valley directly below the turbo. I was wondering if anyone else has had this problem and if so what should i do to cure this problem? Any help is greatly appreciated! I was looking around because i noticed a decent sized "spot" under my truck in the driveway today. I won't be driving it until this is fixed..i don't want it to EXPLODE!!! haha
puddles are no fun
here is my list to find my puddle bango bolt,fuel pump,rubber lines to fuel pump,rubber lines on filter housing,filter housing,o ring an lid for filter housing,fuel heater an water sen on filter housing,fuel lines,etc, remove plactic cover off the motor take a rag an fix it to a stiff wire an clean the fuel up in the valley.get a good light start it up an have a look. the filter housing was leaking on mine took me 3 weeks to find it. drove it every day $500 filter housing to fix an i can not get the d-m thing to start now[ should have paid the $500 decu,on ins ha ha ha ] good luck let me what you find
more likely than not the fuel pump. they have a weep hole on the bottom easily visible with small mirror and a flashlight. i drove mine inthe same condition as yours for about 3 weeks without explosion. if you do conclude it is the weep hole dripping, you'll need to replace the fuel pump. while you're at it, replace the rubber fuel lines also.
hay sargent/wolfe there is a web site that nav-international have. it's an aussie site. it's great in you need a little help finding where thing are here it is hope it will help you.www.nav-international.com.br you will find a botton in the right corner for english hit the international an on the next page to the left side you will services header go to service manual. THIS SITE IS NOT A SPAM SITE IT IS [MWM INTERNATIONAL] THEY ARE THE BOYS DOWN UNDER FOR INTERNATIONAL. i got this site from a shop foreman at the springfeild ohio plant
the part number for the pump at NAPA is M61067 and the line code for it is NFP. You shouldnt need to tell the counterperson the line code but just incase that is it. I know we stock it at the NAPA I work at but I cant vouch for other stores.
oh and I almost forgot, if you have AAA and you show your card you can get a pretty good discount, usually 7%
Franklin
Franklin
Originally Posted by trike1946
Make sure you get a Carter. NAPA is Carter and so is FORD. the weez is right about the price from NAPA. Ford is about $150. Post back if you are going to change it. There are some things to watch out for.
It will start and run mostly like normal until it goes completely. I found it was easier to cut the old hoses off, and take the 2 bolts out of the filter and move it back to get the new hoses on. Change the fuel filter while you are there. Clean it out before you stick in the new filter. It helps to have a second set of hands when you do it.
