1997 Ford F150 alarm problem
I have a 1997 Ford F150. The alarm keeps going off with the doors unlocked. I even push the unlock button on the door panel and on my remote and it still goes off at all times day and night. Any ideas? I thought it might be the factory installed alarm. We had a 'Code Alarm' installed after we purchased the truck in 1997. This year the problem started with the alarm. It happened for a while then stopped. We bought new 'Code Alarm' remotes and had them programmed a couple of months ago. Now, within the last couple of weeks the alarm problem is back. This forum helped me several years ago with the 'door ajar' light staying on. It was recommended that I use WD40 and it hasn't happened since.
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
randymacbc
1999 to 2016 Super Duty
03-21-2012 01:23 PM
TIKT B8
08-31-2010 10:20 AM
