Rear Suspension alternative - Ford Truck Enthusiasts Forums
Old 09-20-2006, 06:38 PM
lynnandtina lynnandtina is offline
lynnandtina is starting off with a positive reputation.
I'm planning my rear suspension, and I have a few questions. My plan is to use nascar truck arms with a 9" using air bags. I'm wondering if I could use a rear trailing arm crossmember for a 60-72 chevy/gmc 2wd truck, since it uses the same type of trailing bars. Does someone have access to a 60-72 chevy/gmc truck to take some measurements for me ? I need to know the width and heigth of this crossmember, and the distance between the ears that the trailing arms get bolted to.
Another alternative is to build my own crossmember, but if I could use a stock piece from another truck, even though it is a chevy, I'd like to go that route.
Thanks
Old 09-20-2006, 07:10 PM
SunDown's Avatar
SunDown SunDown is offline
SunDown is starting off with a positive reputation.
well why dont you make your own cross member? I'm not sure what nascar truck arms look like but if its just a robust square tube 4 link with eyelets at ea end making a crossmener should be a cake walk.
Old 09-20-2006, 07:39 PM
TheSovereign53's Avatar
TheSovereign53 TheSovereign53 is offline
TheSovereign53 is starting off with a positive reputation.
Making your own is probably the best way to do this.
Old 09-20-2006, 07:51 PM
I don't have a lot of fabrication skills under my belt, which is why I was leaning towards an existing design.Truck arms are essentially two 51" long arms which attach to the rear axle in a similar manner leaf springs attach, then attach to the crossmember located midway up the frame similar to an a-arm on a typical front suspension. There's a set on ebay right now for pictures, search for nascar truck arms.
Old 09-21-2006, 12:35 PM
bobbytnm's Avatar
bobbytnm bobbytnm is offline
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
Sounds like an interesting project. If no one chimes in with the GM measurements that you need try the Stovebolt forum;
http://www.stovebolt.com
They are a pretty decent group also. It seems like there was a couple of featured trucks in Custom Classic Trucks or Classic Trucks not too long ago (6 months or so) that had Nascar style trucks in them. The one I remember was a 38 Ford
Good luck
Bobby
Old 11-22-2006, 11:55 AM
For everyones information, The frames are exactly the same dimensions at the crossmember mounting point, The crossmember from the chevy fits perfectly inside the frame rails of the 55, heigth and width.
Lynn
Old 11-22-2006, 05:35 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
NASCAR uses those very same Chevy truck trailing arms. Spring mounts on top the arm in front of the axle. Does require a track bar as well. Correct geometry is when the CL of the bars are extended they meet at the front driveshaft U joint.
Old 11-22-2006, 06:25 PM
That's what I'm using for trailing arms, The NASCAR ones. I'm probably going to be forced to use a 2 piece driveshaft now, since it appears as though the hole in the crossmember was set up for this. The trailing arms have bushings that are approximately 1/16" too long, but they should fit snugly with a little persuasion.
Old 11-22-2006, 06:36 PM
AXracer's Avatar
I'd avoid the 2 pc shaft if at all possible. Weld in a NHRA type driveshaft support oval in the center of the crossmember to give needed clearance.
Old 11-22-2006, 06:44 PM
The 9 inch is also off center. Which is another reason why I was looking at the 2 piece driveshaft. Is the 2 piece too hard to set up or are there other reasons to avoid it ?
Old 11-22-2006, 07:00 PM
AXracer's Avatar
You have a carrier bearing that needs to be supported an extra u joint and slip joint. If the U joint angles are not correctly oriented they will wear out very quickly. The offset of the rear end is a non issue, it assures the U joints do not work in a straight line.
Old 11-22-2006, 07:03 PM
Thanks, I'll look at the support oval.
Lynn
Old 11-22-2006, 10:22 PM
AXracer's Avatar
Summit has a number of different flat and tubular ones you might adapt, search driveshaft hoop or loop, or you could make or have made your own out of 1/4" steel strapping or 3/4" tubing.
Old 11-23-2006, 07:26 AM
I may have backed myself into a corner. The driveshaft appears to be too far to the passenger side to do this. I dont have my 390 sitting in there yet, but I'm using a volare front suspension with the nascar trailing arms and the 9" which the pinion sits about 2" to the left. The crossmember is set up for a center exit with the trailing arms attaching too close to be cutting a whole lot away.Lynn
Old 11-23-2006, 09:11 AM
AXracer's Avatar
Where there's a will there's a way, modifications are the norm when building Hot rods. Do you have pictures? Are you offsetting the engine for the Volare? Many with Volare's off set the engine a couple inches to the right for steering shaft/header clearance. That may produce more clearance issues than the pinion offset. 2" at the rear axle does not angle the driveshaft a whole lot at the tranny, but if it is tight, there are ways to get more room. How far behind the front universal is the crossmember? How far apart are the arm mounts?
Tags
51, alternative, ford, link, nascar, rear, silverados, suspension, suspensions, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
