erratic speedo, OD light blinking, ABS light on, no cruise control
I have a 1999 F250 Diesel, 2 wheel drive with 80K. Just recently the ABs light will not go off after it comes up immediately after startup. No codes come up when I checked them and Autozone checked them. The speedo does not work until I am in second gear around 2K rpm, then it jumps up and performs fine until I drop below that and it drops down to 0. Cruise control does not work anymore. The Overdrive light is blinking. The transmission shifts fine and has full fluid. All of it seems related, is this a VSS issue? Need help quick as this truck will be towing hurricane assistance trailer to Mississppi in 9 days. Thanks
tigers2007
1999 to 2016 Super Duty
16
11-17-2012 04:49 PM
Stone Mathews
04-25-2011 08:58 AM
