Replacing Dash Lights in 1998 F-150 - Page 2 - Ford Truck Enthusiasts Forums
Old 09-27-2006, 05:54 PM
DoofusOfTheDay's Avatar
DoofusOfTheDay DoofusOfTheDay is offline
DoofusOfTheDay is starting off with a positive reputation.
Okay finally decided on blue LED's. I won't get to this until at least next weekend, prolly after, and will document it if I remember.
Old 09-29-2006, 09:47 PM
Blower Bulbs replaced.
Okay I replaced the 2 bulbs behind blower controls. Too much effort to post pictures here, so here is link to online album. Click slideshow to go in order or do one at a time, whatever. You don't have to sign up for anything, just click on link. I would be curious if anybody knows how to determine polarity on bulbs when replacing. Maybe I need to get out a microscope to look on these tiny bulbs for some indicator.
I'll document the gauge bulbs also when I do them, probably in 2 weekends.
http://picasaweb.google.com/DoofusOfTheDay/TruckMods
I think this should work too:
http://picasaweb.google.com/DoofusOf...59574580232210
Old 10-14-2006, 01:46 PM
Changed my dashboard lights(the one's behind the gauges). Not too bad, will try and post pictures and detailed instructions later, but probably tomorrow or Monday. I got to go do some tiling in girl's bathroom this afternoon.
Old 10-16-2006, 12:05 PM
Pics and some instructions for replacing gauge lights on my 1998. I forgot to take a picture of removing the transmission range indicator(you know P, R, N, D, 2 1) You kind of unclip from both sides of it and it drops off the cluster. It was kind of a pain to clip back in since I got big clumsy hands, but not awful to do.
http://picasaweb.google.com/DoofusOf...htsReplacement
I still don't know if there really is a concern with polarity on these bulbs, it seemed to work first shot, or I got lucky on all 5. Does anybody know if polarity does matter on these bulbs?
Old 10-16-2006, 09:29 PM
mneal mneal is offline
mneal is starting off with a positive reputation.
The polarty does not matter, they are incandescent resistance type lamp sand as the currret flows thru from either direction.
Old 10-16-2006, 10:45 PM
Cerberus742 Cerberus742 is offline
Cerberus742 is starting off with a positive reputation.
Does the panel dim still work with the LEDs? I'm about to dig into this, I'll let you know where that top spedo light is.
Old 10-17-2006, 11:45 AM
Yes, panel dim still works. What do you have to do to post images in threads? Seems like I can only put a link to an image at a URL...
Old 10-17-2006, 12:21 PM
Code3's Avatar
Code3 Code3 is offline
Code3 is gaining momentum as a positive member of FTE.
Quote:
First, you have to create a gallery. Be sure to include the pic you want to post. On the forum screen, click "User CP". On the left under the control panel, click "Edit Gallery". Click on the pic in your gallery you want to include in your post. Scroll down to the bottom where it says "[Forum Codes - For displaying image in forum posts]". Click on that. Copy and paste the url into your post.
BTW, thanks for seeing this post through. I've been planning on doing this to my '98 and it's good to have a guinea pig! I find it interesting that my dash is dim in exactly the same spots as yours. Design flaw maybe?
Old 10-18-2006, 09:29 PM
Code3's Avatar
Quote:
Also, could you give us some intel on whether or not there is a bulb between the tach and the speedo? That's the dimmest spot on my dash.
Old 10-19-2006, 05:20 AM
If you look at the photo album I posted you will see one between the Tach and Speedo, down near the bottom of the unit.
Old 01-15-2010, 04:45 PM
soos76's Avatar
soos76 soos76 is offline
soos76 is starting off with a positive reputation.
Your pic by pic instructions on this repair were just awesome. Thanks for taking the time to do it. I had it done in just a few hours.
Quote:
Picasa Web Albums - gregg - Gauge Lights ...
Old 01-15-2010, 05:11 PM
Well glad they helped. Alas though, I sold my F-150 last month. Head gasket leak, and lots of stuff that was rubber or plastic under the hood disintegrating. Now I own a 2008 Ford Escape - v6 Black with 50,000 miles on it.
  #28
Old 01-16-2010, 12:02 PM
fordf150farmer's Avatar
fordf150farmer fordf150farmer is offline
fordf150farmer is starting off with a positive reputation.
the only lights that are goin on mine are the ones behind the speedo and tach. it is the 194's that i need? also what mounts them into the panel? is it the lights themselves or is there a casing on them? i couldnt really tell by the picture. im thinkin about using led's from here Super Bright LEDs - Miniature Wedge Base Bulbs and im not sure what will fit in the pannel. i know they should all plug into the electricall conectors but i want to make sure they will fit the pannel. thanks for any insight
  #29
Old 01-16-2010, 01:03 PM
soos76's Avatar
The black items indicated by the arrows in the pic are sockets removable by a 1/4 CC turn as noted by doofus. The replacement bulbs just plug in. I just did this change out with stock 194's. I have a '97 and if they lasted this long, I will never have to replace them again. FWIW, I would change out all 5 and be done with it. Doofus did a great job on this.
  #30
Old 01-16-2010, 01:27 PM
so do the lights plug in, and then the black part goes over top of it? i agree this was a great pictorial. the only part i dont know about is the actual replacement of the bulbs.
Burnt dome light fix/conversion Sian_Sam Excursion - King of SUVs 25 01-07-2017 09:06 PM
1989 F-150/Bronco - how many dash bulbs? Spktyr 1987 - 1996 F150 & Larger F-Series Trucks 2 02-22-2016 08:53 AM
Headlight Bulb Replacement Ford Big Rig 1999 to 2016 Super Duty 3 03-14-2014 11:18 AM
LED mistake pin8246 1999 - 2003 7.3L Power Stroke Diesel 6 06-03-2013 03:01 AM
'86 Ranger 'HOW TO' replace #194 Instrument Cluster Bulb bozo4ford Ranger & B-Series 4 12-22-2011 08:12 PM
Tags
1997, 1998, 2007, 98, bulbs, change, dash, duty, f150, f250, light, lights, replace, replacing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
