01 overdrive switch on gear selector - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-19-2006, 11:38 PM
turpehar turpehar is offline
turpehar is starting off with a positive reputation.
Need some help. The switch for turning overdrive off thats located on the auto trans shifter stopped working. I've taken off the column cover to see if the wires have been severed from the tilt wheel, but nothing wrong there. I also checked the fuses, and all is well.
Is it possible that the switch is bad at the end of the shifter, or somewhere farther down the column?
Thanks
Old 09-27-2006, 01:42 PM
greenhighboy's Avatar
greenhighboy greenhighboy is offline
greenhighboy is starting off with a positive reputation.
I am having the same problem. How hard is the switch to change? How do you go about changing it?
Old 09-27-2006, 03:40 PM
Talking
I haven't actually changed it yet, but I'll let you know. My wife is bitching up a storm because it doesn't work,,,, not that she would use it. She's just mad cause it won't do what she tells it to do. You know the drill.
Old 09-27-2006, 04:43 PM
Krewat's Avatar
Krewat Krewat is online now
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Tell your wife she wore it out
It's not so much the tilt-wheel that causes the wires to break, it's the selector.
You might want to look further upstream towards the switch to see if any wires are broken.
Many have had the same problem (blowing fuse, no light, no switch function) and it's a broken wire further up than where the entire column tilts.
Old 09-27-2006, 09:58 PM
ol'yeller ol'yeller is offline
ol'yeller is gaining momentum as a positive member of FTE.
I replaced the shifter lever in mine. It took all of about 15 minutes. The hardest part was figuring out how to pull the ignition switch so I could remove the upper column plastic. My wires looked good but they were broken internally at the end of the shifter lever. The switch just plugs in at the end of the lever. From what I hear the wires being broken is much more common than a bad switch. Cost at the Ford dealer for the shifter lever was $49. Easy job.
Greg
Old 09-27-2006, 10:05 PM
Thumbs up
Quote:
Greg
Thanks. I had it apart up to the point of pulling the ignition switch hoping to find a bad wire. Guess I need to pony up and get it done.
Thanks again
Old 09-28-2006, 10:15 AM
ol'yeller,
How did you remove the ignition switch?
Old 09-28-2006, 11:03 AM
sifon187's Avatar
sifon187 sifon187 is offline
sifon187 is starting off with a positive reputation.
Same problem with mine...it worked fine somtimes and other times it would not work. This looks like a great idea for a the tech folder. A how to on shifter arm replacement. I know someone out there knows how to do it and can get some pics of the job.
Old 09-28-2006, 11:58 AM
Quote:
Originally Posted by greenhighboy
ol'yeller,
Prior to disassembly, I disconnected my battery and let the truck sit for 1/2 hour as you are messing around near the airbag. I didn't want any surprises. The key needs to be in the ignition. There is a small hole with a stainless button on the lower part (bottom) of the ignition housing. You can see it when you remove the lower plastic steering housing cover. Depress the button with a small screwdriver or awl while turning and pulling the ignition (key) at the same time. Everything will pop out at once. Be careful of the tiny contact and wire for the key chime. On mine the plastic insulator broke off which made my keychime sound off all the time. A small application of super glue solved that problem.
With the covers off you can see everything very well. Unplug the wires that come out of the column end of the shifter. There are 2 screws that hold the rubber that attaches to the shift lever. Remove those and then drive out the pin that hold the shift lever to the column. The new lever comes with new rubber already attached and mine included the new switch for the $49.
Reassembly is just the reverse of above. A couple of cautions though. Be careful of the key chime wire. It is pretty fragile. Also before you button everything up, work the shifter through all the positions and make sure that the wires on the new shaft don't bind or pull.
All and all this is a very easy repair that can be accopmplished with no specialty tools and no huge technical talent. Trust me I know!
Old 09-28-2006, 12:05 PM
ol'yeller,
Thank you very much for posting that information. When I did a search for overdrive switch there wasn't anything that I could find. I am sure this info will help alot of people in the future. The title of this post will also come up anytime someone does a search for overdrive switch. Thanks again.
Old 09-28-2006, 01:01 PM
Greenhighboy,
Thanks for the kind words. I'm just happy that I could contribute something rather than always looking for help!
Greg
Old 09-28-2006, 01:31 PM
Thumbs up
Prior to disassembly, I disconnected my battery and let the truck sit for 1/2 hour as you are messing around near the airbag. I didn't want any surprises. ............... Trust me I know!
Thanks for the info. I am going to do this and document with pictures and text so it can be posted in Tech.
Old 09-29-2006, 03:33 AM
ordy1 ordy1 is offline
ordy1 is starting off with a positive reputation.
od light
I just purchased a 250 SD had the same problem, decided to swap the switch with the one in my f150 (same switch) . swapped them out and worked good, put the bad switch in the 150 guess what it worked? scratched my head a little, decided to swap them back out to original location both work guess the contact pins had a little corrosion or something I would suggest pulling the switch out check the contacts and reinstall.
Old 09-29-2006, 12:08 PM
Krewat's Avatar
Quote:
WELCOME to FTE!!!
Sounds more like there's a broken/grounding wire and moving them around "fixed" it - temporarily...
Old 10-10-2007, 10:19 AM
frghtr frghtr is offline
frghtr is starting off with a positive reputation.
Ol'Yeller, I just finished my overdrive switch/shifter lever replacement using your excellently written instructions. Before trying this seemingly intimidating task I was ready to hand it to a dealer. Thanks for pioneering this repair and posting it. It should probably be in the most common questions reference if it's not already. I can see where this will be one of the most common repairs needed on the older Super Dutys due to original design problem of short wiring.
After the swap out, I opened the wiring on the old shift lever, after ohming out the ends which showed opens on two wires. Sure enough, the two little wires were broken right where the cable passed through a strain-relief point. This was adding strain instead of helping to relieve it due to the short length of the original cable. I would also recommend checking the button switch with an ohmmeter before replacing it, its probably not the problem.
Either way, the new shift lever has a much longer cable and hopefully will last longer.
Thanks again.
Switching to a tilt column, straight forward swap? GN1220 1999 to 2016 Super Duty 2 01-01-2017 04:41 PM
Overdrive light in the transmission shifter arm... Holmesuser01 1987 - 1996 F150 & Larger F-Series Trucks 21 02-10-2016 09:50 PM
61 F100 Column Shift Parts SThompson 1961 - 1963 F100 Unibody 4 08-14-2015 02:11 AM
shifter tube bushings Jose A. Aerostar 3 04-04-2015 07:42 PM
Overdrive light not on. preparation_h 1999 to 2016 Super Duty 3 07-16-2009 09:18 AM
Tags
1992, 1997, 1999, 2005, automatic, broken, button, excursion, f150, ford, install, overdrive, replacement, switch, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
