01 overdrive switch on gear selector
Originally Posted by crum71
Ok, I am having the same problem, but my speedometer doesn't work when the light on the overdrive button starts flashing. Is this cause the switch is bad? or do I have another problem...
Cheapo part. Not a tranny problem.
I do have a ABS light on, I was told this is because of a bad wheel bearing. I am taking my truck in to have this replaced today. Could this be the reason the speedometer doesn't work,and the light flashes? When the speedometer stops, it takes a few seconds for the light to flash, but you can stop and take off again,and the speedometer starts working again,and then the light goes off.
Would it be on the front? It is the Front hub assembly that is being replaced, on the driver side. The truck does have 4 wheel ABS though.
But the speedo and flashing OD light definitely means the VSS.
I'd change that first.
Are you SURE that wheel bearing is bad?
Originally Posted by krewat
Right on top of the rear end, on top of the pumpkin.
Easy to change.
Easy to change.
#28
shift lever with OD
Thanks Ol'yeller. 15 minutes for the panels, ignition and lever was right on. Finding and disconnecting the wire from the hidden connector under the dash took 2 hours. Figuring in it got dark, the flashlight broke, 6 mosquito bites and a slice on my finger feeling around for the connector. TIP...the connector disconnects by lifting the connection side up slightly. Look closely at the new one to see how it is made.
#29
#30
