F150 Transmission 5 speed OD 1995 - Ford Truck Enthusiasts Forums
Old 09-19-2006, 10:38 AM
fsaburro fsaburro is offline
fsaburro is starting off with a positive reputation.
I have a 1995 Ford F150 XL. It has a 5 speed OD manual transmission. The 1/2 gear shifter fork is worn out. I want to replace it. I have 2 questions:
1) How do I determine what transmission I have?
2) What could have caused the fork to wear out? Could there be other possible problems with the transmission that I need to check out?
The symptoms were the truck would not shift into 1st or 2nd gears but would shift into the other gears.
Old 09-19-2006, 10:57 AM
KW160 KW160 is offline
KW160 is starting off with a positive reputation.
You have a Mazda M5R2 transmission. From reading these forums it appears that this is one weak link in this transmission and can happen fro normal wear. How many miles are on it?
Old 09-19-2006, 10:58 AM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
The transmission should be a Mazda M5R2. I don't know a lot about the transmissions in general, but another common problem I have read about is leaking from the rubber shift rail seals.
Old 09-19-2006, 02:24 PM
Chumbucket Chumbucket is offline
Chumbucket is starting off with a positive reputation.
Trans
Read that white tag on side of transmission to get Ford #number OEM.
Old 09-19-2006, 03:48 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
Moved to appropriate forum per our "Read First!" annoucement at the top of the 87-96 forum...
It's definitely an M5R2 (aka M5OD).
It's not uncommon for the shift fork to go out, if the tranny was working fine previously to that failure...I'd simply replace the worn parts and flush the tranny with fluid. Fill it up and run it, if it works fine then off ya go. If you still have problems than something else is wrong.
Then I'd change it within 50 miles and leave it as long as there are no other symptoms.
I'm meticulous about any metal debris that could be in the tranny from the shift fork so I personally would fluid the fluid and make sure it's clean.
Old 09-19-2006, 04:38 PM
Clubwagon Clubwagon is offline
Clubwagon is starting off with a positive reputation.
Yep, its an M5OD. The forks can be replaced by just pulling the top cover and sliding out the shift rail. Pretty simple.
Worn forks are almost always the result of a driver that won't keep his hand off the shifter. If you rest your hand on the shifter between shifts you are wearing out the shift forks.
The other thing that can cause worn shift forks is a bad pilot bearing. If the pilot bearing is dragging then it requires more effort to shift (as additional pressure is required on the synchro ring to spin the gear up - and you therefore wear the synchro ring too) and that wears the fork. So while you have the transmission out to change the forks, inspect the clutch and pilot bearing. Replace as necessary.
Steve
'95 Clubwagon XLT
Old 11-29-2013, 09:32 AM
captain1997 captain1997 is offline
captain1997 is starting off with a positive reputation.
I have the same trans. just had mine out to do a new clutch and slave and pilot bearing. swapped out the top of the trans for a top that was recently rebuilt.
Since I put the trans back in everytime I let off the throttle it starts grinding and wanting to come back out of gear it never comes back out of gear completely. I either throw it in neutral or hit the throttle.
I pulled mine back out last night and pulled the top back off and dont see anything wrong with it so I dont know what to do with the dang thing
Old 03-05-2015, 12:39 AM
Jeeper1974 Jeeper1974 is offline
Jeeper1974 is starting off with a positive reputation.
Steve
'95 Clubwagon XLT
I have a 1995, but I believe the same transmission. I had just pulled the trans to put in a new clutch. Once it was put back in, there's a weird vibration between 2300RPM and 3400RPM. Then the truck wouldn't shift into first or second, so I replaced the 1/2 shift fork. It was worn significantly. Now, 2000 miles later, once I stop, it's difficult to shift into first or second again. How do I know if the synchro is worn out?
Old 03-05-2015, 02:53 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Welcome to FTE.
Feel free to start a new thread for such questions. No harm tacking on to an old thread, but it may limit responses.
If a synchro is worn out you may get grinding, as it will no longer "synchronize" the gears. If it is just hard to engage, there may be too much torque for the synchro to overcome, especially at a stop.
What oil did you use in the trans? These Mazda tranmissions use ATF. Gear oil will give you these problems.
Your pilot bearing--replaced? Throwout bearing--identical to the OEM item? Clutch bled properly? Clutch master and mount checked for leaks and solid mounting? (cracks in the firewall were common in '80s trucks, and possible in others. Make sure the master is not moving around) Hoses not bulged? Pedal and linkages ok?
Old 03-05-2015, 11:38 PM
I used ford ATF. New throwout bearing; that was the main reason for doing the clutch, the bearing started leaking really bad and I was told that when the clutch gets soaked in brake fluid, it should really be replaced since the trans is out anyways. I checked the hoses since they were fit hoses, no cracks or leaks. The master cylinder doesn't lose any fluid. I bled the system. I checked the pedal and the different linkages that are under the dash and everything seems to be moving smoothly and correctly. I noticed that when the trans gets warm, is when my shifting problem occurs. And not sure if it's related, but if I'm in gear, hold the clutch, hit a bump, there is a knocking in the trans and I can feel it in the shifter. Is it possible that either a motor mount, or trans mount is bad causing the trans to move in ways it shouldn't to be hard to shift?
Old 03-05-2015, 11:55 PM
Possible and worth checking. Also, pilot bearing?
Old 03-06-2015, 12:02 AM
Pilot bearing as well when the trans was out. I was told possibly that the new clutch wasn't balanced from the manufacturer.
Which brand ATF should I use, or is it personal preference?
I'm new to Fords, drove Dodges and Jeeps.
Old 02-17-2016, 02:23 PM
Chris.Short Chris.Short is offline
Chris.Short is starting off with a positive reputation.
Any fix? This is what mine has started doing. Sort of...
Old 11-06-2016, 11:31 PM
John Patton's Avatar
John Patton John Patton is offline
John Patton is starting off with a positive reputation.
So worn shift-forks, would be the main problem ?
M5R2 - Shift fork? tndallas 1987 - 1996 F150 & Larger F-Series Trucks 16 02-06-2017 12:50 PM
1993 f150 5 speed won't shift into gear Highcountry30 1987 - 1996 F150 & Larger F-Series Trucks 5 11-06-2016 11:36 PM
M5OD/M5R2 Shifter Fix or Rebuild Trans? TelefunkenU47 1987 - 1996 F150 & Larger F-Series Trucks 4 05-24-2011 10:28 AM
broken shift fork???? fordtrck302 1987 - 1996 F150 & Larger F-Series Trucks 2 04-05-2008 05:52 PM
M5R2 Transmission Fork Replacement fsaburro Clutch, Transmission, Differential, Axle & Transfer Case 1 09-28-2006 10:48 PM
Tags
1995, 5speed, 95, bearing, change, f150, ford, fork, gear, manual, pilot, shift, shifter, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
