1996 E-350 tripometer and odometer prob.
Is it only the odometer that is giving trouble or is the speedometer also acting up? If the odometer is only acting up you may have a bad PSOM control module which, in my 95, is directly straight up from the steering column behind the dash way up high. If the speedometer is working than the rear axle speed sensor must be OK.
The speedometer always works. Also, the odometer always works. Its just that when I turn the motorhome off, and then turn it on again, sometimes the tripometer has reset itself and the odometer resets itself to ehere it last was.
So, lets say I start the motorhome and it reads 13,500 on the odometer. I drive 15 miles and it then reads 13515. I stop the motorhome, get gas, and key up to start it and the mileage will read 13,500.
Originally Posted by T18skyguy
I think it still has to be the PSOM since it's the brain behind the whole thing. When you push the peg does it re-zero itself OK? Maybe there is some kind of glitch in that PSOM.
TufEnuf
1997 - 2003 F150
06-23-2005 05:45 PM
gantnerg
02-14-2005 10:46 AM
